NV3550 Install - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > NV3550 Install
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 07-30-2012, 06:58 PM   #16
jerresredyj
jerresredyj's Avatar
Originally Posted by nathanninja View Post
When I did my swap, I noticed the pilot bearing I took out was small (about 1" OD). The OEM part number for a 94-95 YJ references a larger (about 1.8" OD). And if you look at the end of the crank, it looked like there was 2 bores for a pilot bearing, the smaller one being farther in, and the larger one being closer to the rear of the vehicle. I was going to try the OEM larger one in the larger bore, but I was afraid it would sit too far back on the input shaft and hit the splined part of the shaft. But it looks like thats exactly what you did, and didn't have any problems?
I felt the same about the larger bore. I measured the best I could and it looked like it would be close. I didn't have to force anything so I'm hoping it will be ok.
jerresredyj is offline   Reply With Quote
Unread 07-30-2012, 07:52 PM   #17
nathanninja
Humph, makes me wish I had used that bearing instead of the bushing. Less friction, plus I had to sand out my bushing to fit, so it's not even perfect. Oh well, at least I'm not the only one. Post back when you know for sure that its not binding anything and I'll amend my info thread to reflect that
nathanninja is offline   Reply With Quote
Unread 07-31-2012, 12:54 PM   #18
Mr.ThunderMakeR
Originally Posted by Karma View Post
The shift tower is not a straight bolt in. You will have to move a mounting tab on the tower to match the bolt pattern on the tranny. I can't easily describe the issue but you will see it. The fix is obvious and requires minor welding on the tower mounting, not on the tranny. I just wanted to mention it so you will know what to expect.
Why did you change the shift tower?
- '91 Jeep Wrangler YJ, 4" lift with 33" BFG AT's, 1" body lift, NV3550 swap, NP241OR Rubicon TCase
- '09 Mazda RX-8 R3
Mr.ThunderMakeR is offline   Reply With Quote
Unread 07-31-2012, 01:30 PM   #19
Karma
HI Thunder,
Because the tower bolt pattern (AV15) did not match the pattern on the transmission (3550).
Sparky
Karma is offline   Reply With Quote
Unread 07-31-2012, 03:40 PM   #20
Mr.ThunderMakeR
HI Thunder,
Sparky
Wouldn't it be easier to retain the NV3550 tower and shifter?
- '09 Mazda RX-8 R3
Unread 07-31-2012, 05:01 PM   #21
Karma
HI Thunder,
I think we are talking about two different things. My '89 YJ came with the AX15 and had the shift tower for that tranny and vehicle. My new 3550 did not come with a tower. Therefore, I had to adapt the AX15 tower to the 3550.
If you have researched this tranny swap, you will find this to be a normal problem. It's not difficult but the mounting tab must be moved for the AX15 tower to mount on the 3550.
Sparky
Unread 07-31-2012, 07:50 PM   #22
jerresredyj
Karma, thanks for the info on the ax15 to 3550 swap but I'm doing a BA10 to 3550 swap.
Unread 07-31-2012, 09:33 PM   #23
Karma
HIjerres,
Oh, I'm sorry. Actually, I knew that but I got confused. I haven't read the front end of thread for a while. That happens a lot.
Sparky
Unread 07-31-2012, 11:46 PM   #24
jamesbland123
1987 YJ Wrangler
Not sure if you drive the jeep in any water, but when I did my 3550 swap I vented the tranny with a nipple so I could use a hose going to the engine bay. The stock vent is a small piece of metal that loosely covers a hole. For most driving is fine, but if you go into water over the top of the tranny you might want to re-engineer that.
jamesbland123 is offline   Reply With Quote
Unread 08-01-2012, 09:33 AM   #25
Mr.ThunderMakeR
HI Thunder,
Sparky
Got you. I'm just gonna make sure I get one with the original shift tower. It looks like most of the ones on ebay have it.
Got any pics? This was something I was already thinking about.
- '09 Mazda RX-8 R3
Unread 08-01-2012, 09:53 AM   #26
Karma
HI,
I don't see the purpose of a special transmission vent. The factory does not supply one. I think the reason is because the transmission vents through the top opening for the shift tower. And that opening is impossible to totally seal. At least, so I've found.
Am I wrong?
Sparky
Unread 08-05-2012, 11:25 AM   #27
jerresredyj
Here's the vent on the NV3550. I'll probably replace it with a barbed fitting and hook up the old vent hose.
Unread 08-22-2012, 08:44 PM   #28
jerresredyj
Installed skid pan Saturday. I had to make the trans mount and torque arm bolt slots about a 1/2" longer towards the rear. I used the Advance Adapters transfer case shifter bracket and had to do some file work on the linkage so I could adjust it about 1/4" shorter. I only had to trim the trans tunnel to clear the transfer case shifter bracket. PO had trimmed the tunnel to clear the shifter when they installed a 3" BL and transfer case drop, both which are now gone. Today I made a trans tunnel cover pattern.
Unread 08-23-2012, 01:58 PM   #29
Mr.ThunderMakeR
Got any more specific info about how you made that pattern? Cardboard? I've been thinking about how to do this as cardboard won't match the curvature of the tunnel. Also is your TCase shifter on the pass side and trans shifter on the driver side? That's opposite of the original YJ layout, but its a good idea.
I'm going to have to get creative as I'm using a TJ tcase shifter handle that mounts to the tub and not the transmission.
- '09 Mazda RX-8 R3
Unread 08-23-2012, 02:13 PM   #30
Opihi59
from here it gets rough
Opihi59's Avatar
Based on the curve of the shifter, the photograph is taken from the passenger side of the Jeep. Front would be towards the right in the image, so the T case shifter is Driver's side and conventional layout.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
