Nv 3550 On 4 Angry Squirrels. - Page 7 - JeepForum.com
post #91 of 338 Old 04-20-2009, 12:17 PM Thread Starter
moonshinefuel
Thanks Rusty for the addition to the thread.
Here are more pictures of the fitment of the pilot on the nv 3550 and the slv. cyl. on the bell. The fit is excellent on everything.
Pictures from top top to bottom.
Front view pilot.
Pilot flush.
Pilot pushed back.
Slv. cyl. mount on bell.
Slv. cyl. inside bell.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #92 of 338 Old 04-20-2009, 12:20 PM Thread Starter
moonshinefuel
Originally Posted by Opihi59 View Post
On your slave cylinder, does it have a fixture that allows it to be bled? Really should have a plug or something to go in the bleeder bore which will be oriented "upwards" when installed. I read the instructions you photo'd, it implies that there is no bleeder nipple, you have to "bench bleed" it before installation, then add the hose, and bleed that as well........ and it certainly sounds as if there are plenty of opportunities for that process to not go completely smooth.
Additionally, don't cut off the white plastic strips on the action rod--they are designed to be installed intact, and seated in the receptacle of the clutch fork. When you depress the clutch for the first time, the straps are designed to break. The tabs don't fall away, they just stay there. Of course, if you remove the straps, you can launch the piston and you generally need a new slave cyl at that point. Good that the instructions covered that in some detail. Others on the forum have had adventures with that strap.
Thanks again opihi, looking into it.
Bow Hunting
post #93 of 338 Old 04-20-2009, 12:41 PM Thread Starter
moonshinefuel
It is very unlikely I will be moving the motor mounts forward for various reasons. Though I think it is an excellent idea. The length of the nv 3550 is approx. 2 inches longer than the ax 5, and I understand the dakota bell housing is almost 1 inch longer than the ax 5 as well, but I don't know the exact measurements yet. So, the j.b. conv. s.s. s.y.e. will take most all of that added length, and in the final measurements I should still be on the plus side of things because of this. The j.b. conv. takes a lot of length off the transfer case. The shifter will be set back a little from the original ax 5 position but for me that is a good thing. I like that. And if it requires a little trimming, I am all for that to.
Bow Hunting
post #94 of 338 Old 04-21-2009, 09:55 AM Thread Starter
moonshinefuel
Hello opihi, I talked to Steve at Advance Adapters this morning. I did ask about the slv. cyl. and how it has no bleeder. He says yes, there is always an issue on this. Apparently it is a Chrysler slv. cyl. and that is the way chrysler did it, he did say something to the point of there should be a bleeder for these, but this is Chrysler.
Bow Hunting
post #95 of 338 Old 04-21-2009, 10:04 AM Thread Starter
moonshinefuel
For anyone following this write up, and you are considering doing what I am doing, I am basically making an effort to follow the popular way of doing this conversion.
Bow Hunting
post #96 of 338 Old 04-21-2009, 10:13 AM
Opihi59
from here it gets rough
Opihi59's Avatar
One of these days....I will come across a discarded external slave and pick it apart. There is an internally threaded nipple that pokes up from the body of the slave. In the bottom, it has some sorta plug, but there is no screw driver slot or hex socket set into it. I have surmised that this is spun in there on a "snap-off" shaft that yields at a certain torque value and leaves the plug in place. My theory is that you could center drill this carefully without generating too much heat, put in an easy-out and then remove this plug. Then you could fashion some sorta bleeder nipple similar to on your brakes, and this would be the bleeder. I'm sure you recognize the next 2 photos.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #97 of 338 Old 04-21-2009, 10:29 AM Thread Starter
moonshinefuel
And let me just add this, Adv. Adapters does not sell "kit" for this conversion. I am following guidelines of people who have successfully done this. I am not concerned too much about stuff like mounting brackets, etc. My main concern right now is the clutch disc, pressure plate, throw out bearing, fork arm, slv. cyl. are all properly working together. Is everything mathematical and correct as far as all the inner dimensions in the clutch from the front to the pilot, to the back of the throwout bearing. High Impact sells the kits, and says it will work, Adv. Adapters Rep. Steve has his reservations as far as the inner workings of the clutch. His take is to completely remove the entire inner workings of the clutch housing of the 96-98 dakota bell housing and use all the clutch components from it. High Impact says different, they say you can re use all of your clutch components except the pilot, disc, and bell housing. I know it is successfully done the way High Impact is doing it, take from it what you will. I like this kind of stuff, so this is interesting.
Bow Hunting
post #98 of 338 Old 04-21-2009, 12:30 PM Thread Starter
moonshinefuel
Basically put, the fundamentals of putting an ax 15 behind a 2.5 are more sound, as it has been done that way from the factory. The nv 3550 has never been put behind a 2.5 from Chrysler, the ax 15 has. The bolt patterns are the same for the ax 15 as they are for the NV3550. I know there is a protrusion above the front bearing retainer that is different, and the bearing retainer itself is different, (smaller) on the NV3550.
So, I will have to see what the difference is, if any in the overall dimensions from front to back there are, between the two.
Bow Hunting
post #99 of 338 Old 04-21-2009, 01:12 PM Thread Starter
moonshinefuel
From Advance Adapters own manual. Quote: "The NV3550 has the same exact configuration as the AX15 transmission." The transfer case side of the NV3550 is the same as the AX15, "with the exception of losing a bit of spline engagement." (the transfer case side).
Bow Hunting
post #100 of 338 Old 04-21-2009, 01:26 PM Thread Starter
moonshinefuel
Found two pictures for comparison. The NV3550 (top), and the AX15 (bottom).
Bow Hunting
Last edited by moonshinefuel; 12-14-2011 at 12:17 AM. Reason: trimming unecessary info
post #101 of 338 Old 04-22-2009, 12:37 PM Thread Starter
moonshinefuel
Begin to calculate pilot depth into NV4500 bushing:
Input shaft lengths:
AX5 is said to be 7.500 inches
NV3550 is said to be 7.875 inches.
The measurements on the bell of the dakota, and the input shaft of the NV3550 appear to be very close to the same, and according to the paperwork I have seen, are the same.
Bow Hunting
post #102 of 338 Old 04-22-2009, 12:52 PM Thread Starter
moonshinefuel
My research shows through the literature, the AX5 bell is approx 1 inch shorter than the dakota bell. If someone finds different, please post. I am posting an underside view of my bell, on my 95 wrangler, with a rather crude, but best i could do measurement of bell, and that looks to be the case, 1 inch shorter.
Bow Hunting
post #103 of 338 Old 04-22-2009, 01:13 PM Thread Starter
moonshinefuel
Three pictures here, one of the AX5 pilot bushing in flywheel, another of the nv 4500 pilot bushing upside down in countersink indicating it will most likely be near flush with flywheel as opposed to being 1/4 inch down into flywheel as the ax5 bushing is, so, this indicates an approx. gain of 1/4 inch on the pilot according to my calculations.
Bow Hunting
post #104 of 338 Old 04-23-2009, 09:11 AM Thread Starter
moonshinefuel
Here is a much more in depth look at pilot comparisons. The NV4500 pilot and the 95 yj wrangler 2.5, AX5 pilot viewed from various angles.
Bow Hunting
post #105 of 338 Old 04-23-2009, 09:40 AM Thread Starter
moonshinefuel
The input shaft length on the ax5 is 7.5 inches. http://www.novak-adapt.com/knowledge/ax5.htm
The bell housing on the ax 5 is said to be 6.875 inches in deep, that leaves .625 inches sticking out beyond the flush surface of the bell. So that difference needs to be made up to reach the pilot. The nv 3550 output shaft is the same exact depth of the bell, 7.875 inches. So, we need .625.
The picture here looks a little more than it is due to a fixed angle. But the closest measurement in the difference between the pilots was 11/32 of an inch, translated to .34375 or rounded to .344 of an inch.
We need .625 to equal the original depth of the ax5 bushing, to do that it looks like an additional .281 is necessary.
Is the end of the input shaft falling into the pilot? Yes, according to my calculations, but, it is short .281 of the original ax5 measurement. If the difference you see missing doesn't bother you than you are fine.That measurement found also has to be compared to the measurement for the proper pilot bushing depth for the nv 3550, not the ax5. So more depth may be required than the missing .281 to satisfy me, as I am the one considering this conversion. My first thought is yes, this will work, but I want to make sure that the pilot doesn't come dislodged somehow, and it is very very unlikely it will, but, I would like to just tack it in there around the outside perimeter of the pilot to the flywheel for a little insurance maybe. And, I am not locked into doing it this way yet, even though the only reported problems I have heard of are with the slave, and making adjustments there. Still thinking about it, and considering all options..
Bow Hunting
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 06:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 04:57 PM
Angry sparrows or squirrels or what?? Bubba3200 TJ Wrangler Technical Forum 16 11-21-2009 10:49 AM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 09:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 07:22 PM
