Nv 3550 On 4 Angry Squirrels. - Page 6 - JeepForum.com
post #76 of 338 Old 04-19-2009, 09:43 AM Thread Starter
moonshinefuel
More exciting t-case pictures.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #77 of 338 Old 04-19-2009, 09:46 AM Thread Starter
moonshinefuel
That's the last of the interior of case for now. I don't think I will have to cut the shaft down for the jb sye kit the less than 9 1/2 inch measurement should do it but of course I will be double checking all of this.
Bow Hunting
post #78 of 338 Old 04-19-2009, 12:36 PM Thread Starter
moonshinefuel
Here are two pictures of the transfer case 1998, np231 (23 spline), the NV3550 (2001), and the 1997 dakota bell housing, all put together temporarily. The progress is steady, looking to order the jb conv. sye. in one week, waiting for the Advance Adapters slave cyl. kit and NV3550 pilot in the mail, should arrive soon, will post full pictures of kit when I get it. Still thinking about moving the engine forward 2 inches as a possibility, also I will need a shifter handle for the transmission.
Bow Hunting
post #79 of 338 Old 04-19-2009, 03:08 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Originally Posted by moonshinefuel View Post
.........I really do not want to buy another shift kit for 250.00 bucks, this one looks fine, I just need the shifter lever. I could not find one on google, and apparently they are pressed on at the factory and are not designed to come off.........
Of course they come off, and they go back on easily too. Look at the photos in this thread regarding removing the shift lever from the shift shaft. You push it back on, and the little nipple in the spring clip snicks into the groove on the shift shaft stub. You can likely come up with a new shifter on ebay, local forums, or even advertise on this forum in the "want to buy" section.
http://www.jeepforum.com/forum/f12/separating-gear-shifter-513891/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #80 of 338 Old 04-19-2009, 03:20 PM Thread Starter
moonshinefuel
Good thing I didn't listen to the guy who owned the jeep salvage yard in Sunland Valley, Ca. He wanted to sell me the whole shifter assembly for a pretty healthy price. He said you can't take them off, you have to buy the whole shifter assembly.. Nice guy huh? I knew something didn't sound right about that. So I politely thanked him for his time and walked away.
Bow Hunting
post #81 of 338 Old 04-19-2009, 04:43 PM
Opihi59
Opihi59's Avatar
For whatever reason, many people believe they cannot be separated...hopefully I am dispelling that piece of misinformation. The shifter for Cherokees is way more commonly found in junkyards, but the bend/length of it is a lot different and can be a but awkward in a YJ. If you can heat and rebend, or weld a different shaft on it that could be the way to go. Otherwise keep a lookout for one on ebay.
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
Opihi59 is offline
post #82 of 338 Old 04-19-2009, 04:48 PM
Opihi59
Opihi59's Avatar
http://cgi.ebay.com/ebaymotors/JEEP-...Q5fAccessories
And also Summit makes extensions if you end up with a Cherokee shifter and need to modify it.
Opihi59 is offline
post #83 of 338 Old 04-19-2009, 04:57 PM
Opihi59
Opihi59's Avatar
Ummmmmm, remembering now that you have an NV3550..........
I am not certain if the stub is set up the same in the 3550 as in the AX15, and I've been sending you links for the AX15. If you need me to measure the square on my AX15 stub, and measure how far from the end the indentations are for the spring clip nipples, I can do that.
I hope I haven't been misleading you on this. Looking at your photos the visible difference I can see is you have grooves cut around your shifter stub the way the transfer case shifter is, while I have small holes set into mine as seen in the photos on one of the links I sent regarding separating the shifter.
Opihi59 is offline
post #84 of 338 Old 04-19-2009, 05:01 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by czjeeper View Post
Added to the FAQ
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #85 of 338 Old 04-19-2009, 05:06 PM
rustywrangler
Added this thread to the FAQ
post #86 of 338 Old 04-19-2009, 05:12 PM
Opihi59
Opihi59's Avatar
There is another thread also in the FAQ by Northjeep who swapped in an NV3550 in place of his BA 10/5. In his photos, the shifter stub on his 3550 looks different from yours. Perhaps if you PM him he can shed some light on the shifter issue.
Opihi59 is offline
post #87 of 338 Old 04-20-2009, 11:08 AM Thread Starter
moonshinefuel
Thanks opihi59, the info you are providing is greatly helping my progress. I am going through all the info. you are giving. I read Northjeeps swap to, and am going to drop in on his thread pretty soon and say hello. It is an excellent thread.
My A.A. parts came in, so here are some pictures of what you get with this kit. Starting with the box, and papers.
Bow Hunting
post #88 of 338 Old 04-20-2009, 11:12 AM Thread Starter
moonshinefuel
And now the kit.
Bow Hunting
post #89 of 338 Old 04-20-2009, 11:17 AM Thread Starter
moonshinefuel
And the pilot. The pilot just doesn't drop in, it just needs a little oil and tapping for it do seat.
Bow Hunting
post #90 of 338 Old 04-20-2009, 12:12 PM
Opihi59
Opihi59's Avatar
On your slave cylinder, does it have a fixture that allows it to be bled? Really should have a plug or something to go in the bleeder bore which will be oriented "upwards" when installed. I read the instructions you photo'd, it implies that there is no bleeder nipple, you have to "bench bleed" it before installation, then add the hose, and bleed that as well........ and it certainly sounds as if there are plenty of opportunities for that process to not go completely smooth.
Additionally, don't cut off the white plastic strips on the action rod--they are designed to be installed intact, and seated in the receptacle of the clutch fork. When you depress the clutch for the first time, the straps are designed to break. The tabs don't fall away, they just stay there. Of course, if you remove the straps, you can launch the piston and you generally need a new slave cyl at that point. Good that the instructions covered that in some detail. Others on the forum have had adventures with that strap.
Opihi59 is offline
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 06:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 04:57 PM
Angry sparrows or squirrels or what?? Bubba3200 TJ Wrangler Technical Forum 16 11-21-2009 10:49 AM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 09:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 07:22 PM
