Nv 3550 On 4 Angry Squirrels. - Page 4 - JeepForum.com
post #46 of 338 Old 04-16-2009, 10:21 AM Thread Starter
moonshinefuel
Looking up into case.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #47 of 338 Old 04-16-2009, 10:23 AM Thread Starter
moonshinefuel
Pump removed, underside view of pump.
Bow Hunting
post #48 of 338 Old 04-16-2009, 10:26 AM Thread Starter
moonshinefuel
Looking straight in, lower left.
Bow Hunting
post #49 of 338 Old 04-16-2009, 10:28 AM Thread Starter
moonshinefuel
Looking to back gears, upper right.
Bow Hunting
post #50 of 338 Old 04-16-2009, 10:30 AM Thread Starter
moonshinefuel
Looking down, left side view, from top.
Bow Hunting
post #51 of 338 Old 04-16-2009, 10:32 AM Thread Starter
moonshinefuel
There is a lot of play in this gear for center of pump, does anyone know if this is normal?
Bow Hunting
post #52 of 338 Old 04-16-2009, 10:35 AM Thread Starter
moonshinefuel
These two yellow lines is the "play" in the gear. When securing shaft, the gear has approx. this much play. Anyone know if this is normal?
Bow Hunting
post #53 of 338 Old 04-16-2009, 10:38 AM Thread Starter
moonshinefuel
There is play in the chain as the cover is not centering shaft.
Bow Hunting
post #54 of 338 Old 04-16-2009, 10:41 AM Thread Starter
moonshinefuel
Looking down into pump where line attaches.
Bow Hunting
post #55 of 338 Old 04-16-2009, 10:45 AM Thread Starter
moonshinefuel
I did notice the chain was binding on the gear when i was rotating gears, but then realized that the shaft is not centered on the gears, and was too far in causing binding, pull the shaft out some and it is fine.
Bow Hunting
post #56 of 338 Old 04-16-2009, 10:53 AM Thread Starter
moonshinefuel
should the pumps center gear have that much play in it? And the two yellow lines on the gear in the picture, should that gear have that amount of play?
Bow Hunting
post #57 of 338 Old 04-16-2009, 11:47 AM Thread Starter
moonshinefuel
These are pictures of the driveshaft that came with the 231, so you can see why I have concerns, it took on a few rocks.
Bow Hunting
post #58 of 338 Old 04-16-2009, 12:01 PM
agentr855
thats how the pump works its fine.
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
agentr855 is offline
post #59 of 338 Old 04-16-2009, 12:14 PM Thread Starter
moonshinefuel
Thank you.
Bow Hunting
post #60 of 338 Old 04-16-2009, 12:37 PM
jeepdude1987
1987 YJ Wrangler
Dude, your helping remove my fear of taking apart my t-case.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 06:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 04:57 PM
Angry sparrows or squirrels or what?? Bubba3200 TJ Wrangler Technical Forum 16 11-21-2009 10:49 AM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 09:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 07:22 PM
