Nv 3550 On 4 Angry Squirrels. - Page 2 - JeepForum.com
post #16 of 338 Old 04-14-2009, 12:12 PM Thread Starter
moonshinefuel
The NV 3550 I will be installing. You can see the protrusion I was talking about above the bearing retainer. It is different than the ax 15, the kit A.A. sells I was told wont work due to that. They may have manufactured a new design since the the last time I have spoke with them, not sure. The bolt patterns are the same as the ax 15's, dimensions, etc. The characteristic front bearing retainer is smaller than the ax 15's.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #17 of 338 Old 04-14-2009, 12:15 PM Thread Starter
moonshinefuel
Top view NV 3550.
Bow Hunting
post #18 of 338 Old 04-14-2009, 12:18 PM Thread Starter
moonshinefuel
1997 bell housing. Dodge Dakota.
Bow Hunting
post #19 of 338 Old 04-14-2009, 12:22 PM Thread Starter
moonshinefuel
2.5 dakota bell housing, 1997. originally for the ax 15 with that year but bolt patters are the same for the nv 3550
Bow Hunting
post #20 of 338 Old 04-14-2009, 12:27 PM Thread Starter
moonshinefuel
These are cast numbers on the bell housing, I believe you can google the 5 digit number and it should lead you to finding out exactly what year this bell housing was, and to what, this will help you identify if you wish to to the same conversion I am currently in the process of. 1996 through 1998 will work.
Bow Hunting
post #21 of 338 Old 04-14-2009, 05:55 PM
asbury
this is good info, i was about to screw up i thought you needed the trans from a dakota all i really need is the bell houseing and then a trans for swap
JEEP NAKED !!
asbury is offline
post #22 of 338 Old 04-15-2009, 10:47 AM Thread Starter
moonshinefuel
I will be using the same clutch required for my year, and chose the Timken throwout bearing. Hopefully it will last longer. The same clutch fork and slave cylinder will also be retained. The clutch disc will be different as the splines are different on the nv 3550.
Bow Hunting
post #23 of 338 Old 04-15-2009, 10:55 AM Thread Starter
moonshinefuel
Back to the 23 spline transfer case. Outer clip for seal cover removed. These clips are strong. Better than average snap ring pliers required.
Bow Hunting
post #24 of 338 Old 04-15-2009, 10:59 AM Thread Starter
moonshinefuel
Removed seal. Using a small chisel and hammer tapping around the perimeter it came off fairly easily.
Bow Hunting
post #25 of 338 Old 04-15-2009, 11:03 AM Thread Starter
moonshinefuel
There is a large diameter clip on the outer bearing race.
Bow Hunting
post #26 of 338 Old 04-15-2009, 11:05 AM Thread Starter
moonshinefuel
Clip removed.
Bow Hunting
post #27 of 338 Old 04-15-2009, 11:08 AM Thread Starter
moonshinefuel
Yes, a bell housing from the 96-98 dakota that came with the 2.5 engine and the ax 15 trans. You can use your own ax 15 trans. that you acquire, or the nv 3550.
Bow Hunting
post #28 of 338 Old 04-15-2009, 12:51 PM Thread Starter
moonshinefuel
p/n cp4198 autozone disc fits perfectly to the nv 3550 splines and has the same o.d. required to make it work.
Bow Hunting
post #29 of 338 Old 04-15-2009, 12:55 PM Thread Starter
moonshinefuel
Top view of bell housing from 1997 dakota, on the nv 3550.
Bow Hunting
post #30 of 338 Old 04-15-2009, 12:57 PM Thread Starter
moonshinefuel
Front view.
Bow Hunting
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 07:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 05:57 PM
Angry sparrows or squirrels or what?? Bubba3200 TJ Wrangler Technical Forum 16 11-21-2009 11:49 AM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 10:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 08:22 PM
