Nv 3550 On 4 Angry Squirrels. - Page 11 - JeepForum.com
post #151 of 338 Old 05-18-2009, 03:24 PM
bigredcherokee
http://www.jeepforum.com/forum/f12/ax-15-internal-external-slave-cylinder-clutch-line-write-up-592098/
take a look at this. This is what I did from Advanced adapters
For those of you in Louisiana visit
bigredcherokee is offline
post #152 of 338 Old 05-18-2009, 03:34 PM Thread Starter
moonshinefuel
Originally Posted by bigredcherokee View Post
http://www.jeepforum.com/forum/showthread.php?t=592098
Thank you. I will be reading this whole thread tonight at work also. Thanks again.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #153 of 338 Old 05-19-2009, 01:16 AM
Opihi59
from here it gets rough
Opihi59's Avatar
.....and yes, that plastic "pad" under the metal part on the external slave just clips off, but you already knew that.....
I suppose if you found you needed further throw of the external slave, you could remove the plastic pad and it would gain you almost 3/32 throw. I imagine it will take a lot of careful measuring and calculating so that your TO bearing isn't always up against the pressure plate fingers and either spinning, or also decreasing clutch plate clamping pressure. It isn't really a simple process to be able to see up inside the bellhousing unless you happen to have a surplus video endoscope laying around or something similar.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #154 of 338 Old 05-19-2009, 01:35 AM Thread Starter
moonshinefuel
No, no surplus video endoscope hanging around the house.
I think it is going to be the opposite problem of the bearing up against the pressure plate spinning, I would think. I will try it as it is when the time comes, with the shim on the front of the slv. cyl. Majority have had no problem with it.
Bow Hunting
post #155 of 338 Old 05-19-2009, 09:06 AM
czjeeper
Originally Posted by moonshinefuel View Post
czjeeper, you mentioned you did the conversion earlier in the thread. You also used the dakota bell housing as well right? I know you have the ax15, and your slv. cyl. is the same design as mine? And you are getting enough engagement as well from the pin to release arm as well, how is everything working out? Good I imagine. I am thinking the pin" on the slv. cyl. has a good range on it to make up for the distance travel for the release arm. It is a bit further due to retaining the stock pressure plate.
That is correct.
I just bought a slave from NAPA and it came w/out the line. I drove the retaining pin out from the one I had, bled the slave, and installed on my line.
From what I've read, the reason people had to modify the push rod was because of the length of the "pivot stud" on the bellhousing.
I don't have ANY issues with shifting or engagement/disengagement.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #156 of 338 Old 05-19-2009, 09:23 AM Thread Starter
moonshinefuel
Ahh, see now that is good information! On post #110, I found mine to rise just about 1 3/8 inches above the cast. I don't suppose you could shed a little more light on this as far as which height was problematic? That would be great if you could.
Bow Hunting
post #157 of 338 Old 05-19-2009, 03:52 PM Thread Starter
moonshinefuel
One thing I did not mention yet was the fact that I am buying bolts right now. I bought 4 so far. This the size that is working to bolt the dakota bell housing to the nv3550 transmission. I have no idea if the ax5 bell housing bolts will work. I have not tried it. I found them at Lowe's Hardware. I think they are $1.75 a bolt. M10-1.25 x 30.
Bow Hunting
post #158 of 338 Old 05-23-2009, 04:26 PM Thread Starter
moonshinefuel
There are different shifter handles for the NV3550. Basically 03 and newer has the cylindrical shaped mount for the handle. The version before this like mine, has the square shape, (2000-2002). These are the part numbers from Advance Adapters for ordering.
The bottom picture is my transmission. I called A.A. and was told to send them a picture of my transmission, and they would send me the shifter for it. Well, I sent them a picture, and they sent me a shifter, but it is for the 03 and up trans. I received the knob too. The knob looks right though, but the knobs are probably all the same. If I had this info I would have just gave them the part number and had them send me the part. It's no big deal, a little annoying but that's how mail ordering goes sometimes and A.A. is a very good company to deal with. No time to post the shifter I received today. But I can at least post these part numbers.
Bow Hunting
post #159 of 338 Old 05-23-2009, 04:33 PM Thread Starter
moonshinefuel
My square shaped transmission mount for handle.
Bow Hunting
post #160 of 338 Old 05-24-2009, 10:12 AM Thread Starter
moonshinefuel
Pictures of the shifter I received. Really nice quality. Looks like Mopar Factory stuff to me. TJ handle and knob. Will be sending the handle back out Tuesday, and maybe the non-bleedable slave to, for credit on something else, like an s.y.e. kit.
Bow Hunting
post #161 of 338 Old 05-25-2009, 01:18 PM Thread Starter
moonshinefuel
At Harbor Freight Tools today, I came across two unexpected finds. The Clutch Pilot Tool Set for $6.99, which will work great because I am retaining my original clutch except the disc and pilot, and this kit will work great for this conversion as the ax5 clutch your going to get the wrong clutch pilot tool with it.
I can say I have pulled more than a few transmissions, and you usually have fluid draining out of the transmission due to taking off the drive shaft, and leaking all over the place. This Transmission Stop Off Tool I found also at Harbor Freight for $3.99 should keep that from happening. I didn't know these existed.
The Lock Ring Pliers I bought today, they were the most expensive at $16.99 from Kragen Auto Parts. I can tell you though, dealing with Lock Rings with small snap ring pliers is no fun, and this set of pliers looks like it is going to save me a lot of grief when putting my transfer case back together.
I am posting these tools because I feel they are relevant to the job and quite possibly may make your life a lot easier if you don't have them.
Bow Hunting
post #162 of 338 Old 05-31-2009, 04:29 PM Thread Starter
moonshinefuel
At Napa today. Received specs. on the clutch disc RCF584.
I will be ordering tomorrow from the Denver Warehouse as this is the location they could find the disc. Denver has it in stock there. 42.00 dollars, plus tax plus 10.00 shipping. About 58.00 dollars total.
As czjeeper mentioned in post #9 this is the disc he went with. I like better than the 4 cyl. application version.
I did return the slv. cyl. kit as well as the wrong shifter from Advance Adapters, and will be going with pre-bled set up.
I did order the new shifter handle and that should be in tomorrow.
Things are progressing.
Bow Hunting
post #163 of 338 Old 06-01-2009, 01:25 AM Thread Starter
moonshinefuel
The reason I wanted to get the specs. before buying the Napa disc was I wanted to review it a little closer at work tonight. Well, I did and it looks like even though the application for the Napa disc is for a larger displacement engine, it appears the two discs are exactly the same, as to illustrate, the top photo is the autozone disc CP4198, (4cyl. Camaro) The 2nd one down is the from the Napa photo spec. page (RCF584). Unless there is something different with the springs, or something I am missing here.
I know of the Centerforce disc that is applicable also, p/n 383824, but I have not seen a graphic for that one yet.
Update, edit in, picture of Centerforce picture 3rd image down. Definitely can see what appears to be a better quality disc. Though at a price, not uncommon to see an asking price of $106.00 for the disc alone online. I did see it as cheap as $75.13 here: Centerforce 383824 Clutch Disc Size 9 1/8 in. 10 Spline By 1 1/8 in.
Bottom picture is another version of the Autozone cp4198, a different supplier that Autozone uses apparantly to get the same part number.
Bow Hunting
post #164 of 338 Old 06-01-2009, 10:53 AM Thread Starter
moonshinefuel
Shifter arrived today from Advance Adapters. Looks like the right one.
Bow Hunting
post #165 of 338 Old 06-09-2009, 11:56 AM Thread Starter
moonshinefuel
Top picture, shifter on transmission. Fits perfectly. Excellent quality from Advance Adapters.
2nd picture down, got all the bolts needed for the bell housing to transmission. I personally used lock washers on top of flat washers, not sure if the original application used lock washers or not, just the way I am doing it. Now I just have to tighten them down.
I should be able to reuse the bell housing to engine bolts. Should be the same.
The dust cover/shield, should work also, between the bell housing and the engine. Will reuse that.
3rd picture down, Advance Adapters p/n 715545. This looks like what I need for my transfer case shifter bracket, the ax5 bolt pattern is different for this bracket, but I have heard of some fabricating the ax5 bracket and making it work. http://advanceadapters.com/product/2...er-cases).html ] Price $41.40
Bow Hunting
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 06:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 04:57 PM
Angry sparrows or squirrels or what?? Bubba3200 TJ Wrangler Technical Forum 16 11-21-2009 10:49 AM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 09:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 07:22 PM
