Nuttered YJ Success! Except.... - JeepForum.com
post #1 of 11 Old 10-21-2007, 01:35 PM Thread Starter
smitkev2
Well everything went perfect with the '90 4.2. Test drove it and was AMAZED at the difference The jeep was pulling up hills that before it would just slowly loose power. With all this success something had to go wrong right!
Well my temperature guage quit working. Everything was working fine yesterday. Is it possible I knocked something loose? Anyone else have this problem or know a solution?
FYI- I put a new water pump & thermostat in about 4 months ago and no signs of overheating.
smitkev2 is offline
post #2 of 11 Old 10-21-2007, 01:41 PM
jbolty
jbolty's Avatar
Sender is at the back left corner of the head, behind the carb. Might have knocked it off, Think it's a purple wire.
jbolty is offline
post #3 of 11 Old 10-21-2007, 01:55 PM Thread Starter
smitkev2
Thanks for the reply, Works like a charm! Now I have NUTTER SUCCESS!!
smitkev2 is offline
post #4 of 11 Old 10-21-2007, 03:56 PM
hdfxrs91
1987 YJ Wrangler
Congrats. I, too, have successfully Nuttered mine yesterday. I had just rebuilt the engine and started it for the first time today. Once fuel reached the carb, I was able to set the timing. Runs like a champ, now.
hdfxrs91 is offline
post #5 of 11 Old 10-21-2007, 07:52 PM
mdwatts11
1979 CJ5
How long does this take? I am thinking of doing this on my newly acquired YJ...
1979 CJ5-Frame up restoration-YJ 4.2L-EMPI Carb-Flowmaster 2 Chamber Custom Exhaust-Motorcraft ignition-4" Skyjacker w/ Nitro Shocks-Dropped pitman arm-Powder coated frame-Basically new everything.
1990 YJ 4.2L, New addition to my garage. 4" POS Lift, 2 inch body, Bulletproof MFG rear bumper 33" BFG MT, Nutter bypass, MC2100 Carb Upgrade.
Jeeps are money pits.
mdwatts11 is offline
post #6 of 11 Old 10-21-2007, 07:56 PM
hdfxrs91
1987 YJ Wrangler
I spent more time hiding the wires in the original loom than the actual work. It did take a little more time finding and plugging all the vacuum ports... they're freakin' everywhere. The only vacuum lines I have left are the distributor, brake booster, and 4wd. And I'm still running the Carter.
Oh, to answer your question, about 3 hours. I work slow, but I make sure it's done right.
hdfxrs91 is offline
post #7 of 11 Old 10-21-2007, 09:07 PM
captncst
Can the nutter be done to the 1990 2.5l? I see info in the search for the 6cyl. but not the 2.5L.
captncst is offline
post #8 of 11 Old 10-21-2007, 09:28 PM
timatoe
timatoe's Avatar
No.
Ten char.
timatoe is offline
post #9 of 11 Old 10-22-2007, 09:23 AM
giggityjeeper
Did I miss something on mine....LOL took me about 20 minutes......I did not hide the wires but.......were you having some.....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #10 of 11 Old 10-22-2007, 03:49 PM Thread Starter
smitkev2
I have never done anything remotely similar to this. This took me 4 hours because I was VERY methodical in what I was doing, tracing wire 3 times to make sure, check this and the link in the first post 4 & 5 times before I cut a wire "just to make sure" I really didn't want to screw the pooch on this. I did it with 100% success, after I found I knocked off the Temp control, which (jbolty) helped me with.
The most time consuming and problematic part of the enitre process is getting the wires back in the loom. Which is the most mindless part, which is good!
I'll post some pictures on my process, I took pic of every step! I hope it will help someone like me who knew nothing of this process.
Seriously, ANYONE can do this! If I can do it... YOU can do it.
smitkev2 is offline
post #11 of 11 Old 10-22-2007, 04:39 PM
camcrazy
1987 YJ Wrangler
It took me 3-4 hours to replace my Carter Carb with MC2100 and do the nutter bypass.
camcrazy is offline
nuttered? xxxDC1xxx YJ Wrangler Technical Forum 2 05-13-2009 09:00 AM
What is a Nuttered 4.2L? Mr_E YJ Wrangler Technical Forum 3 03-22-2009 04:24 PM
My YJ Just Nuttered!! mattlott00 YJ Wrangler Technical Forum 8 01-01-2009 08:59 AM
'88 4.2 nuttered, what all can i rip out? jeepbro's YJ Wrangler Technical Forum 11 06-30-2007 10:46 AM
Nuttered??????? DrlSgt YJ Wrangler Technical Forum 5 02-13-2006 09:43 AM
