Nuttered Out!!! - JeepForum.com
post #1 of 17 Old 06-01-2013, 04:30 PM Thread Starter
busnasty
Nuttered Out!!!
A few weeks ago posted about having issues after nutter bypass. !990 Jeep Yj with Carter Carb wants to start but wont turn over. I was told to replace the ICM, which I did. Completed the nutter bypass, soldered the wires. Still wont turn over. It ran before I attempted the nutter bypass. Any ideas?? Could the carb be bad or the dizzy? I am losing my mind.
busnasty is offline
post #2 of 17 Old 06-01-2013, 04:59 PM
dancytron
Try grounding the black wire that runs from the icm to a bolt below the distributor directly to the negative battery terminal.
Theoretically, it could be the coil or the distributor. You might try to clean up the connections on the coil.
Confirm that it is no spark, that will eliminate the carburetor.
Otherwise, go through the Nutter instructions again and make sure you did it right. http://www.jeepforum.com/forum/f8/ho...bypass-522262/
dancytron is offline
post #3 of 17 Old 06-01-2013, 06:45 PM
Old4X
1990 CJ7
Your snap on connector on top of the coil may be bad . These are the connections the above post is referring to. Replacement is cheap from NAPA.
And add a dedicated ground to the black wire in the 3 wire harness coming from the dizzy
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 17 Old 06-01-2013, 08:52 PM Thread Starter
busnasty
I will try running the a new ground from both the dizzy and icm. the coil is new and I bought a new connector. I will make sure that all the connections are good and run the grounds. Fingers crossed.
busnasty is offline
post #5 of 17 Old 06-01-2013, 08:55 PM
superj
And your timing is right? Not 180 out?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 17 Old 06-02-2013, 09:08 AM
SLCSmoker
Does the motor even turn over? As in crank.. if not its probably your starter solenoid or starter motor (does the solenoid click?). If it DOES turn over but wont start that's a whole different story.
SLCSmoker is offline
post #7 of 17 Old 06-02-2013, 09:23 AM
Old4X
1990 CJ7
The dizzy doesn't need a ground. The ground at the dizzy is for the ICM. And the case of the ICM is isolated, it does not suooly ground to anything.
Old4X is offline
post #8 of 17 Old 06-02-2013, 09:26 AM
Old4X
1990 CJ7
And it wouldn't hurt to throw 5 gallons of gas in the tank just to make sure. It is not uncommon to be out of gas and still show 1/2 full on gauge.
Old4X is offline
post #9 of 17 Old 06-02-2013, 03:03 PM Thread Starter
busnasty
It turns over but wont start. I am going to check the timing and make sure I don't have it 180 out. Would cylinder 3 fire the same as cylinder #1 for timing purposes? Checking cylinder 1 is a pain in the a$$ since I still have the ac in there.
I will try to add some gas as well. Willing to do anything at this point.
busnasty is offline
post #10 of 17 Old 06-02-2013, 03:31 PM
SLCSmoker
If it worked before the Nutter but not now, double check you did the nutter correctly. I ended up running new wires directly from the ICM to the dizzy in the end, saves opening up that wiring harness. Have you checked for a spark? You'll be able to smeel if your getting fuel, or pull a spark plug and see if its wet.
post #11 of 17 Old 06-02-2013, 04:44 PM
CBinDC
I did them same as SLC. Running new wires saves yourself a headache.
CBinDC is offline
post #12 of 17 Old 07-06-2013, 04:03 PM Thread Starter
busnasty
fellas, few weeks ago I posted on my not so great efforts with my nutter bypass. I have done everything. Ran new grounds, soldered the wires, checked the coil connector, pulled spark plug which smelled like fuel...still no start. Cranks like crazy and wants to start but just wont fire up. Have adjusted the timing and I am 99% sure it is correct. I never removed the distributor so that should help too. I have even replaced the ICM.
I followed step by step the nutter bypass, which really isnt too complicated. Does anyone have any clue whats going on?
busnasty is offline
post #13 of 17 Old 07-06-2013, 05:24 PM
dancytron
Have you confirmed you don't have any spark at all?
post #14 of 17 Old 07-09-2013, 10:20 AM
SamzJeep
SamzJeep's Avatar
Did you get it started? If not, have checked/replaced the ignition module? When I did my nutter, the exact same thing happened to me (cranked but no start/no spark). It ended up being the ignition module. Replaced that and it started right up and has been running great since then (couple of years now). Good luck!
SUPPORT OUR TROOPS
SamzJeep is offline
post #15 of 17 Old 07-10-2013, 11:41 AM Thread Starter
busnasty
I actually purchased a new ICM and tried it and still had same crank no start issue. I just picked up another ICM from someone who took it out of their jeep when they did an engine conversation. Jeep ran previously before he parted it out. Going to try to get it started by de-nuttering the engine. Connecting all orginal wires the way they were before. If starts that either I messed up the nutter (which I really dont think i did) or its the ICM. If it doesnt start I am thinking of pushing it off a near by bridge.
busnasty is offline
carter carburator , nutter bypass , YJ
