Nuttered 87 YJ bucking and losing power in gear - JeepForum.com
post #1 of 15 Old 04-16-2015, 08:23 PM Thread Starter
ob1korobi
1987 YJ Wrangler
I know there are other subjects in here with similar problems but I'm coming up short with my particular Heep. My nuttered 87 6 cylinder 4.2 with MC2100 has suddenly started losing power once in gear after being warmed up. If I start her up and just go after a minute, no problem. problem . Once I get around the corner I start sputtering and losing power and when I give it gas in 1st and 2nd I get a lot of bucking as the fuel that is dumping seems to combust. When I pull over and put her in neutral I can rev away. It gets worse and worse and is undrivable. The only way I can get it back home is clutching and raving and basically dripping the clutch to get high rpms and get up to speed. The first few inches on the accelerator I can rev but once the load kicks in it just dies. The reason I am posting this similar problem is because I do not have a TPS and most remedies I am reading it to either tune the tps or replace it. Am I having cat converter issues? Fuel pump? Choke? Throttle body. I will add I have the electric choke hooked up but I also tested this without it hooked up. My pcv valve is also just venting into the engine bay. Not hooked up to the carb like Gronk suggests. I'm kind of at the point where I am pretty lost and not sure what to do. The day before I drove her over 100 miles and was getting around 200 Miles on my tank. Next day, this. Any help is appreciated.
ob1korobi is offline
post #2 of 15 Old 04-17-2015, 04:13 AM
Mike Romain
If it tested the same with the choke not hooked up, you have a choke issue. The choke needs power to open. Unhooked or no power and it stays closed. Have you checked the fuses? Back up light uses same fuse as choke.
Mike
Mike Romain is offline
post #3 of 15 Old 04-17-2015, 04:01 PM
dancytron
Not really on point, but your pvc isn't venting into the engine bay. It is just sitting there closed not venting at all. You will have different problems down the line unless you fix that.
Possibly on point, when did you last do a regular tune up (cap, rotor, plugs and wires)?
dancytron is offline
post #4 of 15 Old 04-17-2015, 08:59 PM Thread Starter
ob1korobi
1987 YJ Wrangler
I just replaced the cap and rotor, plugs wires. Had the timing and carb tuned at a shop. The electric choke was hooked up during that time. Before I just has the adjustment screw set to keep it at enough of an open position that it wasn't really doing anything it seemed. I'll plug it back it and check the fuses and reverse light.
What should the pcv valve be going to?
post #5 of 15 Old 04-17-2015, 09:20 PM
dancytron
Manifold vacuum at the base of the carb.
http://home.sprynet.com/~dale02/vac-pcv.htm
post #6 of 15 Old 04-18-2015, 07:20 PM Thread Starter
ob1korobi
1987 YJ Wrangler
Thanks Dancytron. It was not hooked up before and ran alright but it is for sure best to have it hooked up. I appreciate the help.
Don't Tread On Me
post #7 of 15 Old 04-26-2015, 05:25 PM Thread Starter
ob1korobi
1987 YJ Wrangler
Had free time this weekend. Checked electric choke wiring, and reverse lights. Everything working. Electric choke is moving. I connected the pcv valve too. Too her for a ride and still the same problems. I recently changed the ignition cap, rotors, wires and plugs and it was running really well. Maybe something is out of whack there? I also replaced fuel filter at this time and hoses are new. Maybe fuel pump? Pinched line. I'm seriously stumped. A mechanic is my next step. Hope not though.
Don't Tread On Me
post #8 of 15 Old 04-26-2015, 05:40 PM
paultek6
I hope you followed completely thru with the nutter and also adjusted your timing to 8 degrees BTDC as the instructions tell you
paultek6 is offline
post #9 of 15 Old 04-27-2015, 06:42 AM
Mike Romain
It was running well before or after you changed the wires?
When it messes up, you should open the air filter to verify the choke is straight up open.
Mike
post #10 of 15 Old 04-27-2015, 08:21 AM Thread Starter
ob1korobi
1987 YJ Wrangler
When it is warmed up the choke is straight up. Verified.
For sure I followed the nutter instructions thoroughly. The timing I had to have a mechanic do because I lacked the tools for it. It was adjusted to what made the vehicle run smoothest. It was running fine with that timing. I can't understand how that might come undone somehow or change while running.
Don't Tread On Me
post #11 of 15 Old 04-27-2015, 09:07 AM
paultek6
You stated timing adjusted at shop .If they used the factory specs it will run like crap. If you did the nutter it should be at 8BTDC
Bad load of gas ?
Fuel filters?
Compression test ?
paultek6 is offline
post #12 of 15 Old 04-27-2015, 09:15 AM
Mike Romain
Is your gas tank vent hooked up? If that messes up, it can starve it for fuel. Quick test is to drive with the gas cap loose or loosen the cap when trouble starts.
Mike
post #13 of 15 Old 04-27-2015, 04:00 PM
dancytron
Bad load of gas ?
Fuel filters?
Compression test ?
This might be it. Did your mechanic set the timing at idle? For the Nutter, you set the timing at idle, vacuum advance unhooked and plugged, to 8 degrees. Like a 1980 CJ7. The instructions for stock are different and would give you the wrong setting.
post #14 of 15 Old 04-28-2015, 10:39 AM Thread Starter
ob1korobi
1987 YJ Wrangler
Bad load of gas ?
Fuel filters?
Compression test ?
Good question. Would it all of the sudden start running like crap though after a month of driving it this way? Fuel filter is new, it did start after a new tank of gas though. I have a test kit. I'll definitely be hooking it up.
This was one of the first things I tried because I figured it was after the fresh tank of gas. I don't know if I drove it around enough though. Maybe the lines are old and collapsing and not giving it adequate fuel?
Still not sure exactly on what they set it to but why after a month of driving it this way would it all of the sudden become picky about it?
Don't Tread On Me
post #15 of 15 Old 04-28-2015, 12:13 PM
Mike Romain
The stock gas lines are not ethanol proof, they rot and crack. It seems only FI lines are safe, the carb ones go bad.
You might have an air leak on the suction line between the pump and tank. It won't leak much, but air gets in.
Mike
