Nutter then issues. - JeepForum.com
post #1 of 5 Old 04-10-2010, 07:13 PM Thread Starter
UserX
Nutter then issues.
So I did the nutter today. Adjusted the timing. To 8*. Jeep starts an runs fine. Now...it wasnt doing this before. When accelerating from a cruise at wot. It bogs and then backfires like crazy. Now, when I brought the timing to 8 after the bypass, it was wayyyyyy advanced. What would cause this? Jeep members what say you?
*edit - I have a empi 32/36 degree carb an intake. 4.2l
UserX is offline
post #2 of 5 Old 04-10-2010, 07:19 PM
Burnerman
Burnerman's Avatar
Is the vacuum advance connected to ported vacuum and did you time it at normal curb idle?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 5 Old 04-11-2010, 06:52 AM Thread Starter
UserX
i looked and no. But the ported vaccum fitting on the carb has no hole. Can I change them? Does tht little bugger just unscrew?
UserX is offline
post #4 of 5 Old 04-11-2010, 07:08 AM
4LarXedo4
i'm not familiar with the weber, but one of my vac hoses for the vacuum advance fell off and did exactly what yours is doing. you need to find a way to hook up your distributor to a ported line before you go driving again. If you have EGR still you could tap into that as that should be a ported vac line
4LarXedo4 is offline
post #5 of 5 Old 04-11-2010, 10:52 AM Thread Starter
UserX
Update: Pulled the carb and unscrewed the cap off the port next to the Vacuum Advance. Re-assembled the carb and started. Checked the port for vacuum. There is vacuum there. So I just picked up some vacuum hose and am heading back to the house to see if that was the issue all though I am sure thats what it is.
UserX is offline
Nutter issues! dillman88 YJ Wrangler Technical Forum 3 03-19-2010 06:40 PM
Nutter Mod Completed, Timing Issues trippleb YJ Wrangler Technical Forum 4 05-22-2009 03:00 PM
Nutter Help. DonAltman3 YJ Wrangler Technical Forum 1 05-11-2009 09:48 AM
New problem, still dealing with electrical issues. UPDATED, STILL HAVE ISSUES!!!!! rustywrangler YJ Wrangler Technical Forum 34 02-17-2009 04:51 PM
Can you nutter a 2.5l TBI? unideluxe YJ Wrangler Technical Forum 6 01-01-2009 08:46 AM
