nutter, rush and carb question. - JeepForum.com
post #1 of 8 Old 04-11-2010, 08:48 AM Thread Starter
Yankee-Juliet
I am planning on dumping the Carter BBD for a Weber 38 DGES. I also intend to do the Nutter Bypass and Team Rush. What I need to know is, since I am replacing the carb do I have to do all the upgrades at once or can I space them out? I was gonna replace carb one weekend, then maybe do the Nutter another weekend and finish it up with the Rush upgrade another weekend. I figured maybe Rush could wait but that I would probably have to Nutter the same time I replace the carb because of the computer. It would be easier for me to space the upgrades out but I didn't know if I could drive the Jeep with the new carb until I did the Nutter? Would appreciate any insight on this. Also, when I do the Nutter, can I completely remove the computer unit or does it need to stay under the dash? Thanks in advance for your help.
"I reject your reality and substitute my own." ~ Adam Savage
"Dog-gone it Roy-Jean, how many times do I have to explain it to ya, when I tell ya to put a rock under the wheel, I MEAN A ROCK!!" ~ C.W. McCall
Yankee-Juliet is offline
post #2 of 8 Old 04-11-2010, 09:42 AM
monkeyhouse
I would do the carter last. Do, the nutter, make sure you have it running right, check your timing, then once you are happy, do the teamrush. After everything is stabilized, do your carb swap. I have the exact same engine as you and I have the weber 38 DGES, so if I can help, post on the board, I check in a good bit.
The nutter takes like 15 minutes. Teamrush doesn't take that long either, an hour tops.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3 of 8 Old 04-11-2010, 09:46 AM Thread Starter
Yankee-Juliet
Thanks for the reply monkeyhouse. If Nutter is that quick then I may do carb and Nutter at same time. Do you like the 38 DGES?
post #4 of 8 Old 04-11-2010, 10:12 AM
monkeyhouse
No I love it. I actually did the nutter first and then did a rebuild on my carter, then decided I wanted the weber. Once I put it in, it was like I had a new jeep. I mean wow, the power I was getting. I did the teamrush afterward. There is a very goo thread on the weber install, give it a read.
http://www.jeepforum.com/forum/f12/w...ite-up-382309/
Here's a good link on cleaning up the vacuum mess:
http://www.jeepforum.com/forum/f12/v...14/index2.html
In case you don't have them here are two great threads for the nutter and teamrush respectively:
http://www.jeepforum.com/forum/f8/ho...bypass-522262/
http://www.jeepforum.com/forum/f8/i-...nitive-669495/
post #5 of 8 Old 04-11-2010, 10:16 AM Thread Starter
Yankee-Juliet
Great info!! Thanks monkeyhouse! I am really looking forward to this, probably be a few weeks though, waiting on tax return. Thanks again.
post #6 of 8 Old 04-11-2010, 10:38 AM Thread Starter
Yankee-Juliet
One more question, did you remove the computer or just leave it under the dash?
post #7 of 8 Old 04-11-2010, 10:41 AM
monkeyhouse
Mine is still there.
post #8 of 8 Old 04-11-2010, 01:18 PM Thread Starter
Yankee-Juliet
Great, thanks again!
carburetor , nutter , rush , upgrade
New Carb nutter question blackangus86 YJ Wrangler Technical Forum 0 08-08-2009 07:59 AM
Where to get weber carb for yj (plus related nutter question...) Simian YJ Wrangler Technical Forum 5 06-16-2009 12:29 PM
New 2150 carb, nutter bypass, TFI upgrade question. farmboy1976 YJ Wrangler Technical Forum 3 06-01-2009 08:17 PM
Weber 34/Nutter job/Team rush Driven2it YJ Wrangler Technical Forum 0 03-01-2009 09:00 AM
Nutter Question And Carb... bcameron1974 YJ Wrangler Technical Forum 1 12-25-2008 11:40 AM
