nutter by-pass problem - JeepForum.com
post #1 of 7 Old 06-17-2013, 08:45 PM Thread Starter
lawrenceks56
Has any body done the nutter bypass and then have the spark plugs start to foul in about 100 miles. I did not have this problem before I did this so I am wondering if I did something to cause this to happen. I hooked the orange wire from the distributor to the orange wire on the spark box and the purple wire from the distributor to the purple wire on the spark box.
lawrenceks56 is offline
post #2 of 7 Old 06-17-2013, 08:52 PM
4.7stroker
Did you reset your timing? Set the carb pins to full lean?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 7 Old 06-17-2013, 09:10 PM Thread Starter
lawrenceks56
yes I did set the timing. I have a webber on it and no I did not reset it. would I set it to the lean setting to?
post #4 of 7 Old 06-17-2013, 09:10 PM
Old4X
1990 CJ7
With the Weber you have to follow their directions for setting the mixture. You may have to re-jet depending on what you have
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 7 Old 06-17-2013, 09:22 PM
4.7stroker
I would also use manifold vacuum not Ported. I would also say install a 1983 pre smog distributor with light springs to bring in full timing at around 2200 rpm.
Dwayne
[url]
[url]
post #6 of 7 Old 06-17-2013, 09:35 PM
Old4X
1990 CJ7
Dwayne
Dwayne speaks the truth.
Old4X is offline
post #7 of 7 Old 06-17-2013, 10:03 PM
zeus87gn
1987 YJ Wrangler
Originally Posted by old4x View Post
dwayne speaks the truth.
x 15,4005011
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
