nutter,didnt retime or move stepper needles - JeepForum.com
post #1 of 3 Old 04-12-2010, 04:36 PM Thread Starter
steveluddy
hi people
did the nutter without moving stepper needles or advancing timing. the jeep runs great now.why do i need to do this.ideling at 700 rpm and no skip or whatever happens all the way to 4000 rpms
steveluddy is offline
post #2 of 3 Old 04-12-2010, 05:45 PM
giggityjeeper
maybe it was screwed up before....LOL.....
mine would not even start without adjusting the timing
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 3 Old 04-12-2010, 06:39 PM
4LarXedo4
I nuttered mine after a carb swap and without adjusting the timing it would start and run seemingly "ok". After i put the timing light on it, it was around 0 degree's, so i adjusted it to 8 and and ran much nicer.
why don't you just put the timing light on it to see where it is, everything may "seem" ok, but after running for awhile with the timing off you may damage something. couldn't hurt to check it, unless your absolutely ok with not knowing what your timing is.
4LarXedo4 is offline
nutter bypass stepper motor location.. lancer27 YJ Wrangler Technical Forum 7 04-04-2009 08:59 PM
Needles? Deezul TJ Wrangler Technical Forum 0 01-12-2009 06:38 PM
messed up gauges, needles dont move ex-toyota YJ Wrangler Technical Forum 11 01-26-2005 03:08 PM
Nutter Bypass and stepper motor question natimblue YJ Wrangler Technical Forum 2 11-15-2004 09:32 PM
Stepper motor with nutter bypass Qcwrangler YJ Wrangler Technical Forum 3 06-11-2003 09:22 PM
