Nutter Bypass and Weber Carb - JeepForum.com
post #1 of 9 Old 09-16-2008, 08:51 PM Thread Starter
usmcwrangler
I replaced my stock carb on my 88 Wrangler with a Weber carb. That carb cuts the emission controls totally. Is the Nutter still needed?
On another note, any tips on passing a Cali smog test? I failed miserably last time I tried. Apparently I'm a "gross polluter" of California!
usmcwrangler is offline
post #2 of 9 Old 09-17-2008, 06:36 AM
spshultz
1987 YJ Wrangler
Yes. The computer still controls timing. I was having major issues with pinging. I Nuttered it and it's running muuuuuch better.
If you decide to Nutter it, here's a tip; make sure you definitely twist the two wires together just like the stock wires are. This is so that IF there is a lot of noise in the engine area due to bad wires, plugs, coil, etc the wires will be less likely to pick up on it. Basically it just helps with noise interference.
In my case I Nuttered first and then will be replacing the BBD carb with an MC2150 once it gets here and also doing the Team Rush mod at the same time.
I won't be able to help with the California emissions unfortunately. I just don't know how strict they are during their "visual" inspection if there is one at all.
spshultz is offline
post #3 of 9 Old 09-17-2008, 06:46 AM
roadyrob
1987 YJ Wrangler
your out of luck trying to pass CA emmissions with a weber carb. must be completly stock or switch to a CARB approved fuel injection, either howell or mopar.
roadyrob is offline
post #4 of 9 Old 09-17-2008, 06:55 AM
kharmajavah
Get ready to put that Carter back on. You'll never pass the visual in California. It's got to be everything intact, completely stock.
kharmajavah is offline
post #5 of 9 Old 09-17-2008, 09:50 AM
giggityjeeper
So I have a questionm Im not from Cali and have never been, BUT if you guys are running your rigs on the street, of course tey have to pass air care or whatever you have, but what if its a trailored rig to the trail, does it still have to pass...?
man I could not imagine running with my carter still...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 9 Old 09-17-2008, 11:01 AM
JaikYJ
In california after your vehicle reaches a certain age isnt it considered a classic and the rules and regulations differ? I would still get rid of the carter is a pile. Best of luck.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #7 of 9 Old 09-17-2008, 04:31 PM Thread Starter
usmcwrangler
Thankfully, I don't have to pass the full California smog test. I'm stationed in California but the jeep is registered in Florida. Thanks for the help.
post #8 of 9 Old 09-20-2008, 12:31 AM
the_barbarian
1987 YJ Wrangler
smart..
FWIW and for those of you in positions to use this info. Vt state is VERY reasonable for registrations. i live in NY, and NY wouldn't work with me to get the title taken care of, so i went to VT, explained the situation and walked out 30 minutes later with new plates in hand.
i have to go back next thurs for the inspection, and must get VT insurance to go with it, but i'll let y'all know how that works out. this is legal, and if you can make it to VT for the yearly inspection, it is much easier than MANY more nanny states are...
all that said, i would have preferred to get it registered in NY, but those are the brakes,, NY likes to slit its own throat that way..
Proud owner of 5 jeeps, and certified JEEP Junkie. newest acquisition and current project (read money-pit); 1987 Wrangler Laredo, hard top, leather seats, custom Woodland Camo, 4.2 I6, 5 SP stick, 4X4 (of course).
the_barbarian is offline
post #9 of 9 Old 09-20-2008, 07:00 AM
kharmajavah
That's good news...I think you could probably stick a V-8 on a shopping cart register it here in Florida
After Nutter bypass and Weber mticar1 YJ Wrangler Technical Forum 7 12-16-2012 09:16 AM
Nutter bypass with weber 32/36 carb help pge27 YJ Wrangler Technical Forum 6 02-15-2009 08:17 PM
[b]weber Conversion/nutter Bypass Timing Setting?[/b] snapps1 YJ Wrangler Technical Forum 2 06-03-2005 07:35 PM
nutter bypass and a weber hguffman YJ Wrangler Technical Forum 13 02-12-2005 11:48 AM
Webber carb/Nutter bypass cjb7804 YJ Wrangler Technical Forum 2 06-16-2004 10:38 PM
