Nutter bypass with weber 32/36 carb help - JeepForum.com
post #1 of 7 Old 02-12-2009, 06:44 PM Thread Starter
pge27
I just recently bought a 90YJ. I'm completely new to the jeep world so I'm needing some help. The Jeep has a 32/36 weber on it and everything else is completely stock all the way back to what looks like the original exhaust. Jeep has 206k on the clock so a lot has got to go. Here is what I've done so far.
Replaced: cap & rotor, plugs, wires, thermostat, heater core, blower (from blazer), valve cover gasket, and the catalytic convertor. I've also done the "nutter bypass" on her. But, as of now, I'm lost as to what vaccuum lines I need to keep and what I can toss. I do have to run emissions testing, but it's just the sniffer....no visual. It did, just barely, fail emissions testing on my first attempt. But that was on the way home from picking it up. It was running rough and rich. My questions are.....
What vaccuum lines can I lose and where do they actually hook up? (most were dryrotted and or missing)
Can I lose the lines that go from the aircleaner to the convertor? (forgot what its called)
Probably gonna rebuild the weber. Any advice on different jets and where the best place is to buy a rebuild kit?
All help would be greatly appreciated. Thanks
pge27 is offline
post #2 of 7 Old 02-12-2009, 07:05 PM
dodger889
The only vacum lines that are needed are the ones for the advance ( a ported off carb)and to the vacume for the diconnect one the front axle.
yes you loss the air preheator just cap it off (egr)
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 7 Old 02-12-2009, 07:55 PM Thread Starter
pge27
So I cap off everything at the canister too?
pge27 is offline
post #4 of 7 Old 02-13-2009, 04:53 PM Thread Starter
pge27
Anyone?????
pge27 is offline
post #5 of 7 Old 02-13-2009, 05:08 PM
laffman
This should help alot with the vacuum lines to the Weber. You can lose all the other vacuum lines.
http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
ElvisV04290 is very helpful if you need to ask questions. I kept my canister and EGR connected. There is a good diagram in that write up.
1990 Jeep YJ Laredo 4.2 I-6
2010 Jeep JK Islander 3.8 V-6
1982 Jeep CJ-8 Scrambler 304 V-8
laffman is offline
post #6 of 7 Old 02-13-2009, 05:54 PM
Fjguercio
1978 CJ7
Here is a write up on the Weber Tune & Jet change.
There are some excellent tune up write up links and link for spark plug reading
There is also a great link for the nutter bypass with pics
There is another link for the clean up for the engine bay... if not smog tested... can remove everthing except the PCV, Power Brake, Distributor Advance. You will have to evaluate some of your newer sensors and auto trans have a few sensors that are kept I believe. I stripped everthing on my CJ
Sorry you just did tune up parts.... Hope you saw the TEAMRUSH upgraded parts for bigger cap/rotar with brass parts. If not you still might want to. There is link for that also.
http://www.jeepforum.com/forum/f8/weber-34-dgec-carb-too-rich-jets-tune-jeep-4-2-258-a-631105/
Regards,
Fred
Fjguercio is offline
post #7 of 7 Old 02-15-2009, 09:17 PM Thread Starter
pge27
Thanks for all of the replies. As of now, I'm just trying to get her back up to par and past emissions. Wanna get a DD out of her so that I can park the Stang for a while.
pge27 is offline
After Nutter bypass and Weber mticar1 YJ Wrangler Technical Forum 7 12-16-2012 10:16 AM
Nutter Bypass and Weber Carb usmcwrangler YJ Wrangler Technical Forum 8 09-20-2008 08:00 AM
[b]weber Conversion/nutter Bypass Timing Setting?[/b] snapps1 YJ Wrangler Technical Forum 2 06-03-2005 08:35 PM
nutter bypass and a weber hguffman YJ Wrangler Technical Forum 13 02-12-2005 12:48 PM
Webber carb/Nutter bypass cjb7804 YJ Wrangler Technical Forum 2 06-16-2004 11:38 PM
