-   -   nutter bypass and a weber (http://www.jeepforum.com/forum/f12/nutter-bypass-weber-136668/)
hguffman 02-08-2005 01:32 PM
do these two mods make sense to do together? The Weber Carb isn't a computer controlled unit anyway... so why take the ECU out of a loop if it isn't controlling anything anymore?
COJAM 02-08-2005 01:51 PM
I did it just so I could remove to computer all together. It really will clean up under the hood if you just pull the whole thing.
I did not notice any change in performance from nuttering after the Weber.
rrclimber 02-08-2005 01:59 PM
I did the nutter only because I had done it prior to installing my weber. But you are right there is really no reason other than wanting it completely gone, to do the nutter with a weber installed.
el guapo 02-08-2005 03:04 PM
actually, the computer still controls your timing. go for it - it's only like 2 wires...
COJAM 02-08-2005 03:41 PM
I would time it 12 BTDC after you nutter it.
Tshark299 02-11-2005 09:17 PM
After the nutter do you guys run your distributer advance on manifold or ported vaccum?
CJaredo7 02-11-2005 09:36 PM
Hey, I'm in the CJ crowd...but thought I'd come over here and take a peek...I did the nutter and an MC2150 for a friends YJ...I'd do them both at the same time. I think you really have to do the nutter if you want the weber to work right..because the stock carb has the stepper motor on it and that controls a lot of the goings on if I remember right.
You will want to run your vac advance on PORTED vac to get the most out of it...it may work on manifold but it won't really help anything because it will be too far advanced at lower rpms to be of any good once you get in the upper rpm range. Know what I mean?
Also, I am running mine at like 8*, but I'm running HEI and a MC2100 on my rig...but it's the same 258 6 cyl motor in YJs up to 1990.
neuroplague 02-11-2005 09:53 PM
I did the bypass many years ago and rid myself of that stupid bbd and useless computer. I then dropped in an older non electronic carter from a cj and it worked great for a few years, until it became tempermental and required too much TLC. The weber replaced the Carter legacy in my Jeep and changed the way it drove... WHAT A BOOST OF POWER!!! not to mention its been going 5 years strong and not a single problem yet. I advanced the timing, replaced the clutch fan with a flex fan, installed a K&N plenum, cone air filter and got pretty intimate with the cat and a screw driver. I'd have to say that the increase in power was very noticeable. I attacked the wiring harness when I did my HEI distributor, now most of the harness is gone leaving me plenty of room in the split loom for accessories. You never realize just how many useless wires you have until you trace them back to nothing... I filled a trash bag. Oh .. and to answer Tshark's question.. I took the distributor advance vacuum from the port below the carb.
Tshark299 02-11-2005 09:58 PM
Yeah, I see what you mean with ported but I remember when I was experimenting back and forth it seemed to have less accelerating power on ported which surprised me, so I eventually just left it on manifold. I had the timing set to stock, but maybe I need to mess with that a bit?
CJaredo7 02-12-2005 09:13 AM
Interesting...if it has less accelerating power when you have it on ported vac, then it sounds like it's maybe advancing too much.... try driving it with NO vac advance on the dizzy at all and see what happens. IF it drives much better, then you may want to get a advance curve kit from crane and play with it some... Then this would allow you to re-time the base advance, which should be somewhere between 6-12* (mines at 8*) and play with your idle mixture settings on the carb a little to get the optimum idle result, then you will be able to better troubleshoot the acceleration issue with vac on port. I know it made a big difference on my rig when I did it that way.
Tshark299 02-12-2005 12:28 PM
Hmm... I'll give it a try. As soon as I can find my timing light I'll start messing with it again.
When tuning the carb (Weber), should I have the advance disconnected and plugged when setting the mixture or does that not really matter. I think I read somewhere that it should be, but I never have in the past.
CJaredo7 02-12-2005 12:33 PM
Yes you need to disconnect it and plug it up
Tshark299 02-12-2005 12:35 PM
Wow, that was fast, thanks. Now I have something else to do today.
CJaredo7 02-12-2005 12:48 PM
heeh, i'm at work so I have nothing else better to do right now :)
The time now is 02:35 AM.
