nutter bypass - JeepForum.com
post #1 of 6 Old 09-14-2011, 09:59 PM Thread Starter
rtaylor25
1987 YJ Wrangler
nutter bypass
put the 2150 motorcraft upgrade carb on the 1987 4.2 wrangler keep seeing talk about the nutter bypass was wondering if any one could tell me what it does and if i need one any info would b appreciated
rtaylor25 is offline
post #2 of 6 Old 09-14-2011, 10:05 PM
goldeaglejeep
I stand corrected below.
goldeaglejeep is offline
post #3 of 6 Old 09-14-2011, 10:06 PM
oldtime_ironman
I'm not totally up on the details, but from what I've seen-
The nutter bypass basically takes the computer out of the picture. I think there's 2 wires you have to cut and splice, and it works better with a different distributor. They say it runs *way* better afterwards.
oldtime_ironman is offline
post #4 of 6 Old 09-14-2011, 10:27 PM
Old4X
1990 CJ7
The Nutter removes the computer from the Jeep. It restores the Duraspark ignition to the same configuration as was found on a late 70s or early 80s Jeep 6 cylinder engine................It does not affect any other emission control equipment, and the remaining emission equipment should be kept and functional, it doesn't hurt performance.
Old4X is offline
post #5 of 6 Old 09-14-2011, 10:31 PM
Old4X
1990 CJ7
You should replace the distributor with a pre-smog dizzy or mod yours to pre-smog configuration.................Quite simple, really, just some work with a file on the centrifugal advance base plate. Other than that plate, both dizzys are identical.
Old4X is offline
post #6 of 6 Old 09-14-2011, 10:44 PM
timatoe
timatoe's Avatar
You could look here in the Frequently Asked Questions......
timatoe is offline
nutter bypass! greenmanalishi YJ Wrangler Technical Forum 7 06-05-2009 06:06 PM
Nutter Bypass.. welker YJ Wrangler Technical Forum 0 12-26-2008 09:58 AM
Nutter Bypass workn4livn YJ Wrangler Technical Forum 7 02-12-2008 04:01 PM
Nutter bypass, is it necessary? samahi72 YJ Wrangler Technical Forum 4 03-21-2006 06:33 PM
Nutter Bypass Combee YJ Wrangler Technical Forum 3 07-26-2004 06:44 PM
