nut and bolt size (for leaf spring) - JeepForum.com
post #1 of 10 Old 10-01-2008, 03:06 PM Thread Starter
frumpy
frumpy's Avatar
Anyone know what size bolt and nut goes through the leaf spring and frame?
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #2 of 10 Old 10-01-2008, 03:17 PM
Exparrot
Exparrot's Avatar
The ones for the frame-to-shackle and the shackle-to-spring are 1/2" x 4.5" fine (20) thread. I used Grade 8 course thread (13) when I replaced since it was all I could find.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #3 of 10 Old 10-01-2008, 03:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Main eye bolts are 9/16", according to this write-up.
http://www.jedi.com/obiwan/jeep/greasebush.html
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 10 Old 10-01-2008, 03:32 PM
Exparrot
Exparrot's Avatar
They are. I didn't know these were the ones he was looking for.
Exparrot is offline
post #5 of 10 Old 10-01-2008, 03:35 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks for the verification!
I've had plenty of them out before, but I never had a reason to replace, or measure them so I was going on "what I found online" there. Good to know that it's accurate!
Mean Max is offline
post #6 of 10 Old 10-01-2008, 03:35 PM Thread Starter
frumpy
frumpy's Avatar
Well just looked at it a bit more and the bolt is fine (thought it was messed up but its not) so now I just have to figure out what sized nut (preferably without taking the bolt out).
I guess it would just be a 9/16 course thread bolt? Defiantly not a fine thread
frumpy is offline
post #7 of 10 Old 10-02-2008, 03:31 PM
Exparrot
Exparrot's Avatar
It's a 9/16" bolt, this much I know. I'm not sure what the original was, since I hacked mine off when I installed the lift. I would have to guess it was a course thread, but just to make sure grab one of each.
Sorry I can't help more...
Exparrot is offline
post #8 of 10 Old 10-02-2008, 03:42 PM
Burnerman
Burnerman's Avatar
Fine thread would be 9/16-18, Course would be 9/16-12. The shackle bolts would be 1/2-20. All my bolts are fine thread.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #9 of 10 Old 10-02-2008, 03:44 PM
FarmBoy
It is a standard course thread. I replaced two main eye bolts when I did my lift.
-jeff
1995 YJ 4 cyl auto, 2" BDS springs, BDS shocks, and 1/2 lift boomerang shackles. 31" BFG Mud Terrain.
FarmBoy is offline
post #10 of 10 Old 10-02-2008, 04:30 PM
Burnerman
Burnerman's Avatar
Come to think of it my main eye bolts are course thread. The shackles are fine thread.
96 ZJ.
stuck leaf spring bolt TheBrainB YJ Wrangler Technical Forum 21 06-12-2015 07:54 PM
leaf spring bolt troubles vdubstreets YJ Wrangler Technical Forum 20 08-16-2009 08:38 AM
leaf spring bolt !! richchs62 YJ Wrangler Technical Forum 12 09-06-2007 01:56 PM
Stuck Leaf spring bolt.... k1llerkyle YJ Wrangler Technical Forum 8 08-14-2006 06:13 PM
Leaf Spring bolt. Where to buy? pushead YJ Wrangler Technical Forum 8 10-21-2003 07:46 PM
