NP435 with a flat belly skid? - JeepForum.com
post #1 of 2 Old 04-05-2010, 06:39 PM Thread Starter
Area.3.Fiftyone
I am re-doing the entire drive line in my YJ that I just acquired.
The PO swapped in a 5.0 HO motor, NP435, NP231 with TC drop kit and really didn't do such a good job IMO of optimizing the combo for belly clearance. There is currently no SYE, there are just shims between the axle and springs. (Plans are to swap out the D30 for an 8.8 and I'll point the yoke at the TC output).
The bottom of the NP435 hangs about 5" below the bottom of the frame rails and the skid plate/spacer is just way too low for any serious wheeling.
I put a 1" body lift on it last week and there is a ton of room to move the entire drive line up for additional belly clearance.
I know I'll need a CV rear drive shaft, but is there a limit on just how high you can raise everything before you are putting too much angle on even a CV drive shaft? Is there an "ideal" drive line angle?
Ideally, I'd like to get the bottom of the NP435 even with the bottom of the frame rails. To me, it looks like the motor mounts are welded in upside down, and can easily be raised at least 5" before I start to have bellhousing to firewall issues.
I know it's hard to visualize without pics, but I was just wondering if anyone else is running an NP435 with a flat belly skid.
Pics will follow tomorrow so you can all see what I'm working with.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #2 of 2 Old 04-05-2010, 07:42 PM
joshbaker92yj
Dont think you can because of the shape of the bottom of the tranny. that is why im going with the sm420
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
Flat belly skid plates 1badlj TJ Wrangler Technical Forum 19 11-03-2013 06:51 AM
flat belly skid kasbiker38 YJ Wrangler Technical Forum 5 06-17-2009 01:17 PM
Flat belly skid mods cb19950 TJ Wrangler Technical Forum 5 07-28-2007 03:17 PM
Flat belly Skid YJ-Mike YJ Wrangler Technical Forum 2 02-21-2007 08:17 AM
Flat belly skid? No lift? thebulkinator TJ Wrangler Technical Forum 19 02-27-2005 06:27 PM
