NP231 upgrades - JeepForum.com
post #1 of 8 Old 03-12-2014, 10:46 PM Thread Starter
YJ4LIFE
NP231 upgrades
so I have a leaky rear main seal. Should I put in a SYE or just replace the rear seal? how much more work is it? If I put in a SYE how much more work is it to put in a wide chain and the 6 gear planetary?
Thanks
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #2 of 8 Old 03-13-2014, 05:41 AM
superj
no ideao n any of it but don't forget that if you do the sye, you need a new driveshaft.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 8 Old 03-13-2014, 08:45 AM
AZJEEPGUY1
it all depends on if you want to spend $600 sye you could probably do it cheaper than that that's just a ballpark average. Or $5 for a seal
AZJEEPGUY1 is offline
post #4 of 8 Old 03-13-2014, 03:04 PM
blitz134
Wide chain and 6 gear planetary...very little extra work if you are doing a real SYE (and not a hack and tap) since you have to open the housing all the way up anyways.
But to change the rear seal you should only need to pull your driveshaft, pop the seal out, and put the new one in. And top off fluid if necessary. Your leaky seal could be the result of not having a SYE though...
Unless you had intentions of doing all of this anyways, I wouldn't let a $5 seal be the impetus for dropping over a grand on your tcase...and getting a new rear driveshaft...and changing your pinion angle to be setup correctly to run with new driveshaft.
Current Jeeps (Click to see build threads):
blitz134 is offline
post #5 of 8 Old 03-13-2014, 05:19 PM
RedRockRed
2010 JK Wrangler
I just had my rear TC seal replaced when it was in for brakes; cost me $80 in addition to the brakes.
RedRockRed is offline
post #6 of 8 Old 03-13-2014, 05:45 PM
ghetdjc320
If you are referring to the seal in the tailcone at the slip yoke it is easy to change yourself. There are only 3 bolts holding on the tailcone piece. It's a bit of work to pry out the old one and install the new one but its only like $5 for the part and maybe an hour of your time. As far as the SYE 6-pinion and wide chain kit that is entirely up to you. It will cost quite a bit to install those items. for an 89 NP231 it is hard to find a 6-pinion planetary that fits since they changed the gear cut angle in 95. Also you will need to remove the needle bearings from the main shaft to install the SYE.
-DJC
ghetdjc320 is offline
post #7 of 8 Old 03-13-2014, 06:57 PM
AZJEEPGUY1
That's y I never go to a shop $80 to change a seal they robbed u man. I do all my own work that way I know what was done and it was done right
post #8 of 8 Old 03-14-2014, 09:44 AM
Why J?
Why J?'s Avatar
Wide chain kits and 6 pinion planetary can be had on eBAy for a $100 or so, each.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
