NP231 Transfer case shift linkage - JeepForum.com
post #1 of 3 Old 09-04-2005, 09:46 PM Thread Starter
jeepgiant
Outside of a junkyard, does anyone know where I can get the shift linkage for a NP231 transfer case. I cant seem to find it anywhere on the web. It is going on a 92yj. Thanks!
jeepgiant is offline
post #2 of 3 Old 09-05-2005, 10:38 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
There is not any real 'linkage', just a lever and a single rod. What parts are you missing? Whats wrong with the junkyard solution?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 3 Old 09-05-2005, 07:49 PM Thread Starter
jeepgiant
I only have the actual shifter (the half that comes up past the boot). I am missing everything else. I dont mind getting the pieces from a junkyard, but the junkyards in my neck of the woods dont seem to have anything for a jeep. Also, every time I get a quote from a junkyard, It is sometimes cheaper to get the piece new. I have posted pictures of my transfer case and shifter bracket. Hopefully someone could point me in the right direction! Thanks!
http://www.geocities.com/signalshot/Jeepgiant_92YJ.html
Transfer Case Shift Linkage Elliott YJ Wrangler Technical Forum 6 01-24-2015 04:16 PM
transfer case shift linkage problems after t-case drop heezy101 TJ Wrangler Technical Forum 5 08-29-2006 06:02 AM
screw for transfer case shift linkage mikevsgeek TJ Wrangler Technical Forum 2 08-01-2005 05:27 PM
Transfer case shift linkage? powerstroke01 TJ Wrangler Technical Forum 12 04-19-2005 06:40 PM
TSB for Transfer Case Shift Linkage??? ctcjason TJ Wrangler Technical Forum 2 10-02-2004 11:02 PM
