Np231 slip yoke question - JeepForum.com
post #1 of 4 Old 01-16-2014, 09:11 AM Thread Starter
758879
1987 YJ Wrangler
Hey i have a 87 yj with an 88 np231 and found a sye on craigslist for cheap its out of a 2000 wrangler with a 231 j will this work in my np231? And i have the older style mechanical speedo will this still work with it because i know they switched to digital later on
I would support obama care if it covered my jeep too!
758879 is offline
post #2 of 4 Old 01-16-2014, 09:34 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its one bolt to swap the speedos
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 01-16-2014, 09:34 AM
jokerchief462
Your good my 89 is mechanical
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 4 Old 01-16-2014, 10:33 AM
kloppk
A few things to look out for...
- Spline count. Your BA/10 tranny is a 21 spine output. Be sure the tcase you are considering is also a 21 spline.
- The front output yoke on the TJ tcase is for a CV (double cardan) driveshaft. Your YJ would have a single u-joint.
- The TJ tcase has an electric switch in the spot your YJ case has the vacuum switch for your front axle. Will need to deal with that if you still run the front axle disco with vacuum.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
