NP231 Shifting OUT of 4 Lo VERY Difficult - JeepForum.com
post #1 of 8 Old 04-02-2008, 12:28 PM Thread Starter
Jim93YJ
Jim93YJ's Avatar
Does anyone else have a hard time shifting out of 4Lo? If so is there a fix or linkage adjustment that could be made??
No problems shifting into 4Lo or in or out of any other gears
Thanks
Jim
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
post #2 of 8 Old 04-02-2008, 02:54 PM
sitdwnandhngon
1987 YJ Wrangler
is it always hard to do? can you do it at full stop in neutral, or rolling slightly?
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #3 of 8 Old 04-03-2008, 07:59 AM Thread Starter
Jim93YJ
Jim93YJ's Avatar
Shifting in 4 Lo is easy but to shift out I have to be pushing incredibly hard on the stick and rolling slighlty
AND...
Jim93YJ is offline
post #4 of 8 Old 04-03-2008, 09:11 AM
Alabamaranger
Just had to tear into mine. This site help me a lot to see what going on inside.
http://www.opiebennett.com/images/Je...2015/np231.htm
I would take the linkage off and see if it's still hard to shift it by hand. If it is, than you know something is causing it inside. Pricing parts out, it might be cheaper to get another tc for a spare.
Alabamaranger is offline
post #5 of 8 Old 04-03-2008, 09:13 AM
Alabamaranger
Mine is equal pressure when going from L to H and H to L.
post #6 of 8 Old 04-03-2008, 12:36 PM
sitdwnandhngon
1987 YJ Wrangler
its possible your linkage needs adjusting however if it just suddenly began doing it its probably something internal, Tcases are not my cup of tea, i just go the the boneyard and get a new one if mine breaks, like Alabamaranger said, take it off and see if you can move the lever with your hand, with your transmission in neutral and the tires blocked you should be able to go through all 4 positions with little effort. if you can then adjust your linkage.
4.2 has 0.2 more!
post #7 of 8 Old 04-03-2008, 01:08 PM
Alabamaranger
If it's inside, it's easy to pull the rear half of the case off while still in the Jeep. Took about 20 minutes to take apart.
post #8 of 8 Old 04-03-2008, 03:23 PM Thread Starter
Jim93YJ
Jim93YJ's Avatar
Thanks guys for the input....I did not realize it shoud be easy enough to shift the transfer case without the mechanical advantage of the linkage. Hopefully that is all it is.
AND...
Jim93YJ is offline
need help please (manual tranny shifting difficult when cold) chafalote TJ Wrangler Technical Forum 24 02-01-2016 07:31 PM
Spongy clutch/difficult shifting rob1525 TJ Wrangler Technical Forum 5 10-31-2009 07:37 AM
NP231 Shifting Question pwreconomist YJ Wrangler Technical Forum 2 12-07-2008 05:20 PM
difficult shifting from 1st-2nd langston.4 TJ Wrangler Technical Forum 6 12-01-2006 03:58 PM
difficult shifting nomad6 TJ Wrangler Technical Forum 3 01-09-2005 03:16 PM
