NP231, which shift fork to buy?! - JeepForum.com
post #1 of 5 Old 03-14-2010, 08:40 PM Thread Starter
bradcoudriet
Hey guys, i need the help of the collective hive JF mind again.
My np231 has been broken for a while, and i cracked it open today to find the shift fork had been totally screwed up and basically eaten half of itself away, along with a saggy chain and busted up oil filter.
So, i'm looking to purchase a new shift fork, and i can't figure out which fork to buy, there are a few options, and none of them seem to fit my TC.
Its a 1993 YJ, with a np231 built in 93
On Quadratec there are two forks, both of which do not include my np231's id number. which is: 52097695
4wd has an Omix-Ada fork for the 231 that doesn't list any specific id's
I'm really confused on which fork to purchase. Any help would be greatly appreciated!!
bradcoudriet is offline
post #2 of 5 Old 03-15-2010, 11:50 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Try contacting a shop or seller that deals in transfer cases and repair parts instead of a mud flap and bling retailer like Quadratec.
From the Factory Parts Listing -
FORK, Mode Shift Transfer Case
P/N 4741237 w/Transfer Case 52097888, 52097890, 52097526, 52097696, 52098358, 52098360, 52098487, 52098540, 52098661, 52097696, 52098526, 52098316
P/N 4741237 w/Transfer Case 2098318,52098319,52098471,52098473,52098480,
52098469,52099120, 52099212
P/N 4761227 w/Transfer Case 52097894, 52097695, 52097893, 52098361, 52098362, 52098563
P/N 4338920 w/Transfer Case 53008210
CJ7-Tim is offline
post #3 of 5 Old 03-15-2010, 12:17 PM Thread Starter
bradcoudriet
Thanks for the parts number listing!
post #4 of 5 Old 03-29-2010, 11:32 AM Thread Starter
bradcoudriet
I ended swapping a NP242 from a 2000 XJ.
So now my YJ has Full Time and Part Time 4WD.
post #5 of 5 Old 12-13-2013, 01:54 PM
venutoa
so there are 2 forks for NP231 transfer case...that I learned today.
- one for 2wd and 4wd
- one for high and low gear
The shop I ordered from got the wrong one
FYI: generally change out this fluid more frequently if you are off roading a lot...maybe every 12 months. typically for street driving it should be changed every 3 years.
venutoa is offline
52097695 , np231 , transfer case
shimming D35 4x4 shift fork? xcnick38 YJ Wrangler Technical Forum 4 01-19-2009 02:16 PM
4x4 shift fork removal xcnick38 YJ Wrangler Technical Forum 2 01-16-2009 01:42 PM
NP231 - cutting the mode fork shaft for SYE?? rgs112 YJ Wrangler Technical Forum 2 08-09-2008 08:25 PM
Shift fork? lah2420 YJ Wrangler Technical Forum 5 06-09-2006 08:37 PM
shift fork/4WD tomcat87 YJ Wrangler Technical Forum 2 12-25-2003 02:18 PM
