NP231 Question - JeepForum.com
post #1 of 8 Old 02-19-2014, 05:31 PM Thread Starter
aviationofficer
1987 YJ Wrangler
NP231 Question
I've got an '87 Wrangler. I want to replace the original NP207 with an NP231. I found one out of a 2002 Wrangler that comes with a SYE. Will it work in my '87?
aviationofficer is offline
post #2 of 8 Old 02-19-2014, 05:58 PM
jsipe007
I believe it is possible but I am not 100% sure. If it is we are going to need a bit more info. What transmission do you have and what was the 231 mated to? There are many different input shafts for the 231 family.
jsipe007 is offline
post #3 of 8 Old 02-19-2014, 06:11 PM Thread Starter
aviationofficer
1987 YJ Wrangler
Sorry about that. I have a TF999 which i believe has a 23 spline output shaft. The t-case i'm looking at is also for a 23 spline.
post #4 of 8 Old 02-19-2014, 06:26 PM
superj
Yours had a 207? Mine has a 231 stock on the tf999. You checked the tag? I thought I had a 207 till I actually got under and looked at it
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 8 Old 02-19-2014, 06:37 PM Thread Starter
aviationofficer
1987 YJ Wrangler
Yeah i checked the tag. I thought it had a 231 till i looked.
post #6 of 8 Old 02-21-2014, 09:25 AM Thread Starter
aviationofficer
1987 YJ Wrangler
bump
post #7 of 8 Old 02-21-2014, 09:32 AM
jsipe007
I dug up this link. Might be helpful.
http://www.pirate4x4.com/forum/jeep-...gth-tf999.html
If the spline count is the same I can only imagine length being the issue.
Here is another link
http://www.bc4x4.com/faqs/yj.cfm?cat=6&faqid=141
jsipe007 is offline
post #8 of 8 Old 02-22-2014, 08:57 PM
jeepguy85
1987 YJ Wrangler
If you can, separate them and count the number of splines if you are not 100% sure. IF it is a 23 spline input, run it unless you plan on an SYE. The only advantages a 231 offers over the 207 are better aftermarket support for SYEs, etc and a 2.72 gear ratio vs the 2.62 on the 207.
EDIT: I just reread your original post. The 87 uses a mechanical speedo. The 2002 TC will be electric. If the spline counts match up, you will still need to adapt the new TC to a mechanical speedo setup.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
