np231 question? - JeepForum.com
post #1 of 8 Old 11-07-2013, 09:30 PM Thread Starter
rtillery34
1987 YJ Wrangler
np231 question?
The np231 can only be attached to the dreaded ba10/5 one way...right? In other words it cant be clocked wrong? The studs only seem to a line one way. Im in the middle of reassembling my transmissions/t-case and dont want to get it together and under the jeep and its clocked wrong! Thanks for the input!!!
rtillery34 is offline
post #2 of 8 Old 11-07-2013, 10:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If its wrong, its way wrong
Luck Favours The Prepared
Anticanman is offline
post #3 of 8 Old 11-08-2013, 11:59 AM
jeepguy85
1987 YJ Wrangler
I just swapped in an NP231 AMC last weekend on my Jeep. The clocking is perfect on the TC I used. I had to remove one of the mounting studs on the face of the TC though because my BA10 only used 5 mounting holes to tie the tranny and TC together.
EDIT: When I installed the TC, it was almost parallel to the belly pan. If your TC is almost parallel to the ground, you should be OK.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #4 of 8 Old 11-08-2013, 12:54 PM
Mark05059
the 231 your putting in came from the same jeep? If it didn't then you might have a Cherokee 231?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 11-08-2013, 01:05 PM
jeepguy85
1987 YJ Wrangler
I think mine came from a Cherokee as well. I had read that they would require a clocking ring, but this one did not. Now I am not 100% sure, but I am betting mine was a Cherokee TC simply because it says NP231 AMC and the manufacture year was '88.
post #6 of 8 Old 11-08-2013, 01:13 PM
jeepguy85
1987 YJ Wrangler
Also, you can buy clocking rings that clock up and down. So make sure you have the correct ring for your application, if you are using a clocking ring.
post #7 of 8 Old 11-08-2013, 02:04 PM
SeanB95YJ
I thought it was the same ring?... up or down just depends on how you line up the holes in the ring
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #8 of 8 Old 11-08-2013, 02:09 PM
jeepguy85
1987 YJ Wrangler
Some do, some don't. I looked at one that they wanted to know if you were doing a driver/passenger drop and also clocking up/down for the application. I was just bringing it up so the OP didn't inadvertently buy the wrong one. Like I said though, mine went on without one.
