-   -   np231 question? (http://www.jeepforum.com/forum/f12/np231-question-1769962/)
rtillery34 11-07-2013 09:30 PM
np231 question?
The np231 can only be attached to the dreaded ba10/5 one way...right? In other words it cant be clocked wrong? The studs only seem to a line one way. Im in the middle of reassembling my transmissions/t-case and dont want to get it together and under the jeep and its clocked wrong! Thanks for the input!!!
Anticanman 11-07-2013 10:58 PM
If its wrong, its way wrong
jeepguy85 11-08-2013 11:59 AM
I just swapped in an NP231 AMC last weekend on my Jeep. The clocking is perfect on the TC I used. I had to remove one of the mounting studs on the face of the TC though because my BA10 only used 5 mounting holes to tie the tranny and TC together.
EDIT: When I installed the TC, it was almost parallel to the belly pan. If your TC is almost parallel to the ground, you should be OK.
Mark05059 11-08-2013 12:54 PM
the 231 your putting in came from the same jeep? If it didn't then you might have a Cherokee 231?
jeepguy85 11-08-2013 01:05 PM
I think mine came from a Cherokee as well. I had read that they would require a clocking ring, but this one did not. Now I am not 100% sure, but I am betting mine was a Cherokee TC simply because it says NP231 AMC and the manufacture year was '88.
jeepguy85 11-08-2013 01:13 PM
Also, you can buy clocking rings that clock up and down. So make sure you have the correct ring for your application, if you are using a clocking ring.
SeanB95YJ 11-08-2013 02:04 PM
I thought it was the same ring?... up or down just depends on how you line up the holes in the ring
jeepguy85 11-08-2013 02:09 PM
Some do, some don't. I looked at one that they wanted to know if you were doing a driver/passenger drop and also clocking up/down for the application. I was just bringing it up so the OP didn't inadvertently buy the wrong one. Like I said though, mine went on without one.
The time now is 02:46 PM.
