NP231 problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > NP231 problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IRuffstuff XJ Unirail Channel Reinforcement....
Unread 12-31-2010, 10:25 AM   #1
bpr
NP231 problems
My buddy had problems on his 89 5speed, 4cyl with popping noise going from 1st to 2cd when you get on it. Seemed worse in a turn. Kept getting worse and started doing it in all gears. We checked everything ball joints, tie rods, ujoints, rear end. Finally decided it was either TC or tranny. Pulled TC first and this is what we found. Input gear and shift hub appear to be toast.
Can he use a TC from a 97 or 98 TJ with 4cyl motor? Will input gear be 21 spline and correct length? Any other differences to deal with?
bpr is offline   Reply With Quote
Unread 12-31-2010, 11:24 AM   #2
SteveJcoYJ
yes and i did it
http://www.jeepforum.com/forum/f12/t...ite-up-697384/
SteveJcoYJ is offline   Reply With Quote
