np231 mounting stud size? - JeepForum.com
post #1 of 12 Old 05-04-2012, 09:20 AM Thread Starter
janders82
2010 JK Wrangler
I've been searching, but can't seem to find an answer...
Does anyone know what size the mounting studs are for the NP231 to bolt up to the AX-15?
janders82 is offline
post #2 of 12 Old 05-04-2012, 09:33 AM
dadstoy
The part that the t-case slides onto, the part sticking out, is a 3/8"-16, if I remember correctly, but the part that screws into the tranny is a different thread.
dadstoy is offline
post #3 of 12 Old 05-04-2012, 09:46 AM Thread Starter
janders82
2010 JK Wrangler
thanks. i think i may have foud it.
double ended stud
3/8"-24SAE i believe is the end that screws in the TC
someone correct me if i'm wrong, but I believe the studs are:
3/8"-24SAE x 1" -- 3/8"-16USS x 5/8"
post #4 of 12 Old 02-06-2013, 11:48 AM
jeepsurf
double ended stud
This is the correct size. How do I know? I just replaced a few.
I know this thread is old, I just wanted to verify it for anyone who may encounter this later.
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #5 of 12 Old 02-06-2013, 01:52 PM Thread Starter
janders82
2010 JK Wrangler
Its been a while, but i believe i found it somewhere on a NP231 diagram online. Went to the dealer to order the part an matched it up with their specs. Fit perfectly
2010 JKU Automatic w/ 5.13 Gears
2.5" TeraFlex w/ Rancho XL9000s
17" XD Addicts
295/70/17 Nitto Trail Grapplers
post #6 of 12 Old 02-06-2013, 02:26 PM
muddigger0829
I have question. I have 2 broke studs which broke during shipping. Any advice on getting these broke ones out. I drilled - and tried to use a easy out on 1 stud but the easy out broke. How many can you be missing and still be ok. The ones that are broke are side by side. Which I don't. Like the idea of running it with these 2 missing.
muddigger0829 is offline
post #7 of 12 Old 02-07-2013, 08:49 AM
Flajeeper1
1987 YJ Wrangler
Seeing as how the case is out of the jeep. Weld a bolt to the broken stud, use PB blaster on the broken stud and let soak, repeat and then remove. Been there done that!
Flajeeper1 is offline
post #8 of 12 Old 02-07-2013, 09:02 AM
muddigger0829
That would be a great idea if there were enough meat hanging out. Broke almost flush. I'm going to try soaking with pb drill heat and try an ex out again. Maybe with pb and heat I won't break another ezout. Last try too. If I break another one ill have to get another front half.
post #9 of 12 Old 02-07-2013, 09:12 AM
Flajeeper1
1987 YJ Wrangler
Good luck. You might go to a small machine shop and see what they would charge to get them out.
post #10 of 12 Old 07-16-2013, 10:22 PM
zjosh93
Weird, it should be a common Dorman part. I think 675-003 should work depending on how long the shoulder length is.
http://www.dormanproducts.com/catalo...ec17_Part1.pdf
RockAuto sells a pack of ten for $3.90.
EDIT: Just realized that I posted this in the old thread. That's what I get for having so many JF tabs open at once.
zjosh93 is offline
post #11 of 12 Old 07-16-2013, 11:03 PM
5-90
5-90's Avatar
1988 XJ Cherokee
It's a double-ended stud.
The part that threads into the case is threaded 3/8"-16, the end that accepts the nut is threaded 3/8"-24.
(There are sound engineering reasons for doing so, but there isn't enough force here for them to apply.)
The studs may be removed and replaced with threaded rod (3/8"-16) and nuts to match, or you may use a hardware store stud threaded 3/8"-16 - as long as the center section isn't too long to allow for proper clamping with the nuts.
www.kelleyswip.com/tech.html, follow the links.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #12 of 12 Old 07-17-2013, 06:19 AM
Kuntryboy816
Kuntryboy816's Avatar
Originally Posted by muddigger0829 View Post
That would be a great idea if there were enough meat hanging out...
TMI
....try an ex out again.
This is never a good idea. Even if it's just an occasional "hookup" they tend to get clingy and want to get back together. Just remember why they're an "ex"
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
4.0L head stud size? atomicjoe23 YJ Wrangler Technical Forum 0 10-18-2011 06:40 AM
mounting NP231 to 545RFE and need advice JAC1502 TJ Wrangler Technical Forum 2 09-26-2010 03:29 AM
yj wrangler lug nut stud size and knurl size dish1600 YJ Wrangler Technical Forum 3 10-22-2009 03:12 PM
stud size? Muddeprived TJ Wrangler Technical Forum 3 08-03-2005 01:04 PM
Lug Nut Stud Size? 1990WranglerYJ YJ Wrangler Technical Forum 1 04-20-2005 09:01 AM
