NP231 Linkage removal - JeepForum.com
post #1 of 14 Old 11-01-2008, 11:49 PM Thread Starter
95wrangler4life
Trying to find out how to remove the linkage from the range shifter. Cant seem to get mine off and need to do so to replace the unit. also the wonderful book says the piece is attached by a bushing, and i dont feel much of a bolt there so i am guessing that is true, how do i remount it to the new range shifter?
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #2 of 14 Old 11-02-2008, 12:30 AM
OVERLAND_YJ
hey, the shifter linkage is attached to a bracket by a single bolt that does in fact go through a bushing before it goes through the linkage. to remove the whole thing there are 2, 1/2 inch nuts on top of the tranny and then one bolt on the drivers side of the tranny (maybe 9/16th's) and then the bolt that goes through the bushing that holds the actual linkage to the bracket. if your trying to get the lnkage disconnected from the tranny it is a simple single nut.
(all this info is from a 92 4cyl YJ with an AX5 tranny)
Dont forget to wave, OVERLAND...
OVERLAND_YJ is offline
post #3 of 14 Old 11-02-2008, 01:17 AM Thread Starter
95wrangler4life
no nut holding the linkage piece to the shifter itself at the bottom of it and thats where I need to remove it and to remove the shifter housing and then reattach it to the new housing.
I have already tried removing the top 2 bolts and the bottom bolt but can not slide it off the other bolt until the linkage is removed which means i cant take the unit off either
Build thread:
post #4 of 14 Old 11-02-2008, 04:07 PM Thread Starter
95wrangler4life
Anyone have anything for me?
Build thread:
post #5 of 14 Old 11-02-2008, 07:58 PM
xeroid81
Is that piece in the photo from a '95 yj? It looks nothing like the one I removed from mine.
xeroid81 is offline
post #6 of 14 Old 11-03-2008, 11:32 AM Thread Starter
95wrangler4life
i am assuming, its from a different post from my other section related to this problem, but the new one i have sitting here looks close to the same as this one
Build thread:
post #7 of 14 Old 11-03-2008, 12:03 PM
E_ROCK
Mine were bushings and the shift linkage just pressed into them. I just pressed them out and pressed them back in.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #8 of 14 Old 11-03-2008, 09:26 PM Thread Starter
95wrangler4life
right, guess thats my next step to try
Build thread:
post #9 of 14 Old 11-04-2008, 07:45 AM
jeepin1995
jeepin1995's Avatar
gonna throw this out there..... there's a 4th bolt holdong the shifter bracket on the trans/t-case. it's actually one of the t-case mounting bolts, up behind the shifter bracket. did you remove it? also, the linkage should just pull out of that shifter
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #10 of 14 Old 11-09-2008, 07:35 PM Thread Starter
95wrangler4life
so after removing the linkage, it did pull out with some force from the bushing i changed the unit out, removed the bushing and put it in on the new unit and then pressed the linkage thing back into it. There is more play than my other one had, not alot though. It shifts into 4hi and netural but will not stay in 4 low, it doesnt shift far enough to get in completely, i didnt think that the linkage moved since it was pretty rusted into that piece that holds it to the shifter, but it must have, right? Can anyone else think of something different it could be?
Build thread:
post #11 of 14 Old 11-10-2008, 08:26 AM
E_ROCK
You just need to adjust the linkage now. There is a aluminum block with a single bolt in it. One end of the block presses into the bushing on the shifter. If you loosen the bolt, the shift linkage can lengthen or shorten. To me, from the way you describe it, you linkage is too short.
E_ROCK is offline
post #12 of 14 Old 11-10-2008, 10:57 AM Thread Starter
95wrangler4life
yep thats what i was thinking, my problem was when trying to remove the linkage before I did remove that bolt and try to push the linkage bar out that way but its in there, the hammer didnt move it, or atleast i thought it didnt move it but it must have so if its good and rusted in there then what, try banging it back through some with a hammer? I really didnt think i moved it but I am between 1/4in to 1/2in short!
Build thread:
post #13 of 14 Old 11-10-2008, 02:05 PM Thread Starter
95wrangler4life
Well that is definatly rusted on there and isnt moving, even after 2 days of PB Blaster, and even trying to add pressure using a jack and my frame, just wont budge to let me move the damn thing in and out to adjust the linkage. So where do I find the replacement linkage, everytime i search it i get stuff about getting a novak, but I dont want one at this time, just want to get it fixed and done for a little while. So if anyone has or knows where to get the linkage itself, please let me know, if you have one for me, it must not be froze in there like mine currently is.
Thanks
Build thread:
post #14 of 14 Old 12-22-2008, 02:53 AM
snakeroo
Heyas,
So ok, my 93 YJ won't disengage out of 4LO. And there is suddenly play in the 4WD shifter stick. And I'm actually able to pull the stick UP a few inches.
It's firmly attached to the square shaft on the shifter assembly, so that black plastic "isolator" part is fine.
I looked under and saw that big bolt(3/4"?) on the transfer case shifter assembly (as seen in schecterguy's images in this thread)
is MISSING. It must have backed itself out, I guess? Anyway, can someone tell me what size/length...part number? it is? Can I maybe
just pick one up at the hardware store? As opposed to paying a ridiculous amount for the OEM one from the Jeep dealer. (I tried looking for the bolt on the ground(snow!)
where this happened, but no luck)
Thanks
Blue 1993 Wrangler YJ, 6cyl, 4.0L 5spd, 140K miles.
snakeroo is offline
i have a TJ np231/ax5 in my YJ, need linkage help SteveJcoYJ TJ Wrangler Technical Forum 1 03-06-2012 10:25 AM
removal of np231 from ax5 Mark05059 YJ Wrangler Technical Forum 11 01-24-2010 08:32 PM
BA10/5 with NP231...4WD shift linkage? Toms87 YJ Wrangler Technical Forum 5 05-08-2009 08:52 PM
NP231 Shift Linkage themoneypit YJ Wrangler Technical Forum 2 01-18-2007 05:34 AM
NP231 Transfer case shift linkage jeepgiant YJ Wrangler Technical Forum 2 09-05-2005 08:49 PM
