NP231 linkage question. - JeepForum.com
post #1 of 6 Old 01-24-2011, 08:07 AM Thread Starter
seanmac777
I have swapped an AX15 and NP231 from a 95 yj into my 89 YJ. The only thing left is connecting the transfer case shift rod.
The rod is connected to the transfer case, but not connected to the shifter. On the shifter, the bushing is there, and on the rod I have the trunnion with the nipple that needs to go into that bushing.
It all seems to be adjusted correctly, as the rod and the bushing line up perfectly, only problem is....I can't get the rod to go into the bushing. I have gotten it lined up and tried pliers, I wedged a screwdriver through the crossmember and tried prying it on, I've tried tapping it in with a hammer.
Does anybody have a suggestion on how to get this to go in?
I have searched, and found one post where a somebody said that there is a special tool? Does anybody know what tool they mean?
Thanks, Sean.
seanmac777 is offline
post #2 of 6 Old 01-24-2011, 09:19 AM
kloppk
Make sure the plastic bushing is installed in the correct direction.
Then put some lube on the linkage nipple and the plastic bushing.
Line them up and use a pair of channel locks to push the arm nipple into the bushing.
Ahead of time be sure to clean up the arms nipple to remove and rust or crud.
kloppk is offline
post #3 of 6 Old 01-24-2011, 09:43 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
It fits, just takes the perfect angle and elbow grease.
I used a pry bar for leverage and forced mine into place. ^^ I like the vice grips idea.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #4 of 6 Old 01-24-2011, 11:39 AM Thread Starter
seanmac777
Ok, thanks guys. Just wanted to make sure I wasn't doing it wrong. I didn't want to end up breaking it.
post #5 of 6 Old 09-08-2011, 10:11 AM
Meisenslimer
I'm having a hell of a time trying to get the bushing off of the rod to replace it. Anyone have any advice on that?
Meisenslimer is offline
post #6 of 6 Old 09-08-2011, 01:14 PM
Hghgrad
I hit it with a propane torch for a few seconds and soften it up. Sometimes I just melt them completely out
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
i have a TJ np231/ax5 in my YJ, need linkage help SteveJcoYJ TJ Wrangler Technical Forum 1 03-06-2012 09:25 AM
BA10/5 with NP231...4WD shift linkage? Toms87 YJ Wrangler Technical Forum 5 05-08-2009 07:52 PM
NP231 Linkage removal 95wrangler4life YJ Wrangler Technical Forum 13 12-22-2008 01:53 AM
NP231 Shift Linkage themoneypit YJ Wrangler Technical Forum 2 01-18-2007 04:34 AM
NP231 Transfer case shift linkage jeepgiant YJ Wrangler Technical Forum 2 09-05-2005 07:49 PM
