-   -   NP231 linkage question. (http://www.jeepforum.com/forum/f12/np231-linkage-question-1158097/)
seanmac777 01-24-2011 08:07 AM
I have swapped an AX15 and NP231 from a 95 yj into my 89 YJ. The only thing left is connecting the transfer case shift rod.
The rod is connected to the transfer case, but not connected to the shifter. On the shifter, the bushing is there, and on the rod I have the trunnion with the nipple that needs to go into that bushing.
It all seems to be adjusted correctly, as the rod and the bushing line up perfectly, only problem is....I can't get the rod to go into the bushing. I have gotten it lined up and tried pliers, I wedged a screwdriver through the crossmember and tried prying it on, I've tried tapping it in with a hammer.
Does anybody have a suggestion on how to get this to go in?
I have searched, and found one post where a somebody said that there is a special tool? Does anybody know what tool they mean?
Thanks, Sean.
kloppk 01-24-2011 09:19 AM
Make sure the plastic bushing is installed in the correct direction.
Then put some lube on the linkage nipple and the plastic bushing.
Line them up and use a pair of channel locks to push the arm nipple into the bushing.
Ahead of time be sure to clean up the arms nipple to remove and rust or crud.
Poke 01-24-2011 09:43 AM
It fits, just takes the perfect angle and elbow grease.
I used a pry bar for leverage and forced mine into place. ^^ I like the vice grips idea.
seanmac777 01-24-2011 11:39 AM
Ok, thanks guys. Just wanted to make sure I wasn't doing it wrong. I didn't want to end up breaking it. :)
Meisenslimer 09-08-2011 10:11 AM
I'm having a hell of a time trying to get the bushing off of the rod to replace it. Anyone have any advice on that?
Hghgrad 09-08-2011 01:14 PM
I hit it with a propane torch for a few seconds and soften it up. Sometimes I just melt them completely out :)
The time now is 01:50 PM.
