np231 input gear - JeepForum.com
post #1 of 7 Old 07-05-2012, 12:23 PM Thread Starter
stevedude19
np231 input gear
So I want to use the t case that was behind my ax-5 which has a 21 spline input . And I'm trying to figure out which input I need to swap in to use the ax-15 I just got. The tcase year is 95 the ax-15 came out of a 96 Cherokee. Thanks
Sent from my Samsung galaxy S 2 using JeepForum because iphones are so last year
95 YJ Rio Grande 2.5L 4cyl 30" BFG ATs 4 inch rc lift 4.0L TB Cold air intake (302 swap in progress)
2010 JK 6 speed
stevedude19 is offline
post #2 of 7 Old 07-05-2012, 12:41 PM
Siva283
23 spline shaft is what you need.
Ask me how I know...
Siva283 is offline
post #3 of 7 Old 07-05-2012, 01:09 PM Thread Starter
stevedude19
But what size?
I'm looking to buy this one
http://www.ebay.com/itm/231-J-Jeep-T...item2a1e9abe6f
2010 JK 6 speed
post #4 of 7 Old 07-05-2012, 01:15 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Originally Posted by stevedude19 View Post
But what size?
You need to read thru this: http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm
There is significant variation in the input gears, not just limited to the spline count. There are several lengths, different bearing widths, and gear cuts. I'd give Novak a call and they'll help you come up with the input gear you want.
Since your AX15 came from a Cherokee, you will find that the clocking of the transfer case is different and the T case will tip lower on the Driver side than your original. To remedy this, you will need to redrill the mount holes on the tailshaft of the transmission. This is easy to do. I'll look for the writeup on this and post it in if I can find it.
Try this-not exactly what I was looking for, but read Mean Max's input. There may be a writeup lurking around, but from reading the text in this string, you can do this. http://www.jeepforum.com/forum/f12/c...-case-1053744/
It will at least get you started.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now
post #5 of 7 Old 07-09-2012, 11:16 AM Thread Starter
stevedude19
thanks for the info.
do you know if i can just swap the ax5 21 spine shaft with the ax-15?
2010 JK 6 speed
post #6 of 7 Old 07-09-2012, 11:30 AM
Opihi59
Opihi59's Avatar
As in remove the mainshaft from the AX 5 transmission and drop it into the AX15 transmission? No. They are not compatible. Even if it were possible, it would require complete tear down of 2 transmissions to do which would be a task with a complexity several orders of magnitude greater than swapping out an input gear in a NP231.
post #7 of 7 Old 07-09-2012, 11:33 AM Thread Starter
stevedude19
Haha ok thanks. i was pretty sure it wasn't too doable . Im thinking ill just look for a different 231
2010 JK 6 speed
