Np207 and np233 compatibility - JeepForum.com
post #1 of 3 Old 02-21-2013, 07:47 PM Thread Starter
sbaucom
1987 YJ Wrangler
I have an np207 transfer case that's gone bad. Not sure what the gear is called but it's a big gear, with three small gears inside it .. This inside part it stripped. I also believe that the forks are bad. I was wondering if I could pull the guts out of an np233 and put those in it to make it work.
If not can I use the np233 case instead? There are guides to convert one of these into a manual shift .
is there any way possible I can make eithor of these work? Using parts from both.
I realize that the way the np233 bolts to the transmission is different, could I use the front half of the np207 so that it bolts on the same?
Also what kind of wiring would I have to do to make it work?
And one more question .. On top of the np207, is that just a vent line or is it a vacuum line that goes to something? I recently put a motor and tranny into my 87 yj and the transfer case is the only thing I'm having problems with
I also have access to a np241 if I need to use parts from it.
Thanks a ton!! Hoping that there is a professional on transfer cases on this forum haha
sbaucom is offline
post #2 of 3 Old 02-22-2013, 08:59 AM
Que89YJ
Novack will give you a bunch of info:
http://www.novak-adapt.com/knowledge...on_gateway.htm
IDK but you can definitely call them and they will help.
Que89YJ is offline
post #3 of 3 Old 02-22-2013, 10:02 AM
Mark05059
get rid of the electric shifted transfer case and get a 231 out of a cherokee.. either that or see if the scrap yard will swap with you.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
np231 , transfer case , yj wrangler
