NP 231 Yoke Seal - JeepForum.com
post #1 of 12 Old 04-13-2011, 06:18 AM Thread Starter
Mazoo
NP 231 Yoke Seal
Have to change the seal on the tail shaft. Lo and behold the tail shaft is damaged from previous work (that's where the leak was). Have the new tail shaft cone, seal and yoke. Thinking it would be easier to install seal on tail shaft before I bolt it back in. Working on my back and all. Good idea or not so much.
Mazoo
Mazoo is offline
post #2 of 12 Old 04-13-2011, 07:17 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would definitely install the seal on the cone prior to bolting the cone on the housing.
Is there a bushing in the new cone already?
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 12 Old 04-13-2011, 07:23 AM Thread Starter
Mazoo
Yup bushing already installed.
Thanks just needed re assurance.
Mazoo
Mazoo is offline
post #4 of 12 Old 04-13-2011, 07:24 AM
glenn-91YJ
glenn-91YJ's Avatar
I think Max meant to say "bushing" in the tail cone (housing extension) behind the seal. You'll want to make sure that is in place or you will leak ATF even with a new seal. I think I used a 30mm socket to replace mine.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #5 of 12 Old 04-13-2011, 08:40 AM Thread Starter
Mazoo
Glenn--already installed from Quadatrac. Nice Renegade, should post mine. Mostly stock except for tires and some diamond plate bolt on stuff. Getting it back on road for warmer weather, gets better mpg than my Tacoma.
Mazoo
Mazoo is offline
post #6 of 12 Old 04-13-2011, 12:26 PM
glenn-91YJ
glenn-91YJ's Avatar
Mazoo
Thanks. Post a couple...not many of us guys left! Putting a family bar in this weekend. New pads showed up today. Feel better with 3 point belts in the rear.
-Thomas Jefferson
post #7 of 12 Old 04-13-2011, 07:28 PM
NonRubicon
Keep in mind that if the slip yoke shaft is worn, you will still leak even though the bushing and seal are new. I learned this first hand.
NonRubicon is offline
post #8 of 12 Old 04-14-2011, 06:19 AM
glenn-91YJ
glenn-91YJ's Avatar
Me too! I replaced the seal and bushing and it was still leaking. Once I replaced the yoke...problem solved.
-Thomas Jefferson
post #9 of 12 Old 04-14-2011, 06:36 AM Thread Starter
Mazoo
Oh goody---I'll try this first with the new housing, brass bushing, seal, yoke and u joint. If not, that's why they make oil drip pans for awhile.
Mazoo
Mazoo is offline
post #10 of 12 Old 06-27-2011, 11:49 AM Thread Starter
Mazoo
Glenn--Here's a couple
Finally got around to it. 91 Renegade
Mazoo is offline
post #11 of 12 Old 06-27-2011, 12:02 PM
glenn-91YJ
glenn-91YJ's Avatar
Wow...that bad boy still as the original front skid plate on it. I'll assume the rear is on as well.
-Thomas Jefferson
post #12 of 12 Old 06-27-2011, 12:12 PM Thread Starter
Mazoo
Yup
I'm talking to a steel fabricator (who I do work for) to re do them in aluminum diamond plate.
Mazoo is offline
How to seal NP231 yoke? planedog YJ Wrangler Technical Forum 9 06-06-2011 04:46 PM
Yoke / Seal Differences? D35, D44, Rubi D44 lupinsea TJ Wrangler Technical Forum 4 12-21-2010 10:07 PM
dana 44 yoke oil seal question hecubus TJ Wrangler Technical Forum 3 12-02-2007 04:48 PM
slip yoke seal cj847 TJ Wrangler Technical Forum 0 11-11-2007 05:45 PM
Yoke and seal wheelinman03 TJ Wrangler Technical Forum 2 05-26-2006 12:36 AM
