NP-231 to NP-242 swap - JeepForum.com
post #1 of 1 Old 04-01-2010, 09:59 AM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I will be doing this swap this weekend, and have a quick question. The 242 is coming out of a 99 XJ, and therefore doesn't use the vacuum switch for the front axle. I have already permanently locked the CAD, so can I just remove all of the vacuum lines from the transfer case to the front axle, and plug the vacuum line from the engine?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
