NP 231 J Rebuild and SYE install - Page 2 - JeepForum.com
 1Likes
post #16 of 30 Old 05-09-2010, 08:25 PM
nj95yj
please check the pics I would love yo use this write up to help rebuild my t case... thanks
One lovely blue 97' with 33's and 4 pissed off hamsters under the hood
nj95yj is offline
post #17 of 30 Old 05-09-2010, 10:01 PM Thread Starter
EZAces
I will redo the picks tomarow did not know they got moved
EZAces is offline
post #18 of 30 Old 05-11-2010, 08:58 PM Thread Starter
EZAces
I redid all the pics for you guys hope it helps.
EZAces is offline
post #19 of 30 Old 01-27-2011, 03:23 PM
chaserYJ1990
I guess this is as good a place as any that I can find in the FAQ's.
Has anyone replaced their "NP231 VACUUM 4WD SWITCH"? I'm going to be doing this this weekend and was wondering how difficult it's going to be. I'm guessing just unscrew the old one and screw the new one right in? Is there going to be any fluid loss from the NP231 when I take the old one off? I would think not...
Thanks in advance for any help, never messed with a transfer case, EVER! :-) should be fun!!!!
chaserYJ1990 is offline
post #20 of 30 Old 01-27-2011, 07:42 PM
The1AndOnlyBug
Yeah you just unscrew the old one and put the new one on, no fluid loss. If you need one and can wait a few days I got one that I bought offline new for $10 you can have it for the cost of shipping (should be really cheap), depending on what store you go to depends on how much they cost, I got the one that's in the jeep at carquest for $16.
My Vehicles
'89 Wrangler 4.2 .....Sold......
'08 Grand Prix GXP 5.3 V8 303 hp 323 ft-lb tq, my baby =D ..... SOLD.......
'94 wrangler 4.0, parted out/traded off
'94 Wrangler 4.0 K&N cold air, bored throttle body, head polished, Comp cam, 4.5" RE extreme duty, ubolt flip, 1" booms, 1" daystar body, M.O.R.E shock mount extenders rear, shock mount extenders on front, D35 W/ Richmond Lunchbox, 4.56 Gears, 35/12.5/15 Pro Comp M/T, Black D steelies, Front bumper W/ Stinger and winchplate (Armorology), Warn XD9000I, Dakota seats,Kenwood KDC-MP342U head unit, Soundbar with Kicker DS65's, Kicker DX200.4 Amp, Kenwood 6X9 on bottom of rollbar, Infinity 4X6's in dash, Tuffy Glovebox, 4 100W Daylighters, and a CJ hardtop.
2012 HD Night Rod Vivid black stock =D
R.I.P. Chad Daniel French 29 July 1982 - 25 Oct 2010 I'll Miss you Bro
The1AndOnlyBug is offline
post #21 of 30 Old 01-28-2011, 07:49 AM
chaserYJ1990
Thanks for the info and the offer, but I have already purchased the part and it should be here today. Thanks so much for your help!
post #22 of 30 Old 06-01-2011, 06:59 PM
ZeroGravity
Could this please be stickied? Wish I had this when I did my 231...
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #23 of 30 Old 11-07-2011, 10:08 AM
Rockabilly
My 93 YJ already had the SYE when I purchased it last year. Now the rear seal for the yoke is leaking. Is the seal the same as the factory seal? How can I find the part number if it is different?
Rockabilly is offline
post #24 of 30 Old 11-18-2011, 06:45 PM
Duvalbulldog
Can you do a switch with the electronic speed sensor. I bought a used ax15 and it came with the transfer case. My set up is a mechanical speedometer and I want to switch this part instead of tearing down the both to get the input shaft. If anyone could help that would be awesome thanks. I know it's friday.
The obvious is usually looked over when the worst is assumed
Duvalbulldog is offline
post #25 of 30 Old 11-18-2011, 07:01 PM
raynmaker
Nice writeup Aces.
Rockabilly the seals might be different. I found Napa to be the best place to check and if you take the old one they can match it. Might be worth the trouble of pulling the entire tailcone off and taking it with you incase no one has it you can put it together and drive it.
Duval the tailcones are the same for both mech and elec speedo. It is only the sender that is different. I am not sure about the gear that turns the speedo. they may be different. just have to look at the sensor gears and compare.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #26 of 30 Old 11-18-2011, 08:24 PM
Duvalbulldog
Originally Posted by raynmaker View Post
Nice writeup Aces.
Thanks raynmaker thought that it might be the same just had to remove and install but wanted to ask before started taking apart and needing extra parts. very excited about this swap ready to get that po ba out and get that ax in.
post #27 of 30 Old 11-21-2011, 08:21 PM
Rockabilly
[QUOTE=raynmaker;12529873]Nice writeup Aces.
Raynmaker: Thanks for the info. I ended up following a wheelin buddy's advice and cleaned the area real good to discover it was seeping through the splines of the yoke. A little bit of black RTV on the inside of the yoke and the leak is gone.
post #28 of 30 Old 03-03-2013, 10:02 PM
cubsfan92
i have a 1997 wrangler and need a new transfer case. will a 2003 liberty t-case fit on it? thanks
cubsfan92 is offline
post #29 of 30 Old 06-23-2016, 05:50 PM
bobjp
What is the dimension to which you press the needle bearing into the planetary gear assembly. I know you said you used the "old shaft". Did you press to a stop?
bobjp is offline
post #30 of 30 Old 06-23-2016, 06:28 PM
bruinjeeper
bruinjeeper's Avatar
Beach248 likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
yo rebuild or not to rebuild that is thi question njdpb22 YJ Wrangler Technical Forum 22 12-01-2010 07:07 PM
Aussie Locker Install Difficulty? DIY? Dealer Wants 1k To Install.... rastaangel TJ Wrangler Technical Forum 14 04-12-2010 07:00 PM
Jeep Engine to Rebuild or Not to Rebuild booyia TJ Wrangler Technical Forum 31 10-02-2009 12:16 PM
Rebuild 4.2 or install chevy 350 madjeep1 YJ Wrangler Technical Forum 2 12-27-2008 05:49 PM
Finally, Pics of CB install, Rock Ready bracket,Stabilizer and HI LIFT install. franco802 TJ Wrangler Technical Forum 14 02-01-2004 11:26 PM
