NOW whats wrong with my Jeep!!! - JeepForum.com
post #1 of 6 Old 04-02-2004, 02:09 PM Thread Starter
Parabola
Alright...a couple days ago the mechanic put new heater hoses in my Jeep...Ever since then the CHECK ENGINE lite has been on and it has like no power...1st gear gets almost no power until 2000 rpms...3rd and 4th gear sputter and lose power really bad when you give it alot of gas...it never had this problem before...any ideas?
its a 93 YJ with about 120,000 on it
Parabola is offline
post #2 of 6 Old 04-02-2004, 02:59 PM
Greencar
Greencar's Avatar
could be a couple of things... what is your engine, and for the diagnostics check here: http://minimopar.knizefamily.net/fault/index.html
Black 1994 YJ 2.5L
SOA
Greencar is offline
post #3 of 6 Old 04-02-2004, 04:14 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Check
a)if he reveresed the lines
and
b) if he left the coolant way low.
- Ernie
Richmond88yj is offline
post #4 of 6 Old 04-03-2004, 01:29 AM
Ramblin
Could be something else got worked loose or soaked when the work was done. Check ignition system and all connectors on TB, etc.
Does the problem occur when cold or after warmup?
Ramblin is offline
post #5 of 6 Old 04-03-2004, 01:38 AM Thread Starter
Parabola
its a 4 banger..has to be 20 characters long..
Parabola is offline
post #6 of 6 Old 04-03-2004, 08:53 AM
hambubba
why?
Originally Posted by richmond88yj
Check
and
Why do you think this? The heater water from the water pump is "no load" to the engine. That is, the pump is running whether the heater is open (with flow) or closed.
Low coolant would result in overheating, which should be obvious, and will be evident once the engine is warmed up. His problem is immediate, with a cold engine.
I'd look for a loose vacuum line. And learn to change heater hoses - one of the simplest repairs on any (almost) vehicle.
hambubba is offline
whats wrong with my jeep? cr125racer YJ Wrangler Technical Forum 12 01-03-2013 12:19 AM
whats wrong with my jeep SWAMPED YJ Wrangler Technical Forum 4 08-31-2007 03:26 PM
Whats wrong with my jeep?! ClemsonRocks YJ Wrangler Technical Forum 4 12-01-2006 02:29 PM
whats wrong with my jeep? hauganater2315 TJ Wrangler Technical Forum 9 06-12-2006 08:57 PM
whats wrong with your jeep 89_Sahara YJ Wrangler Technical Forum 42 12-02-2005 06:22 AM
