Now that Superior is gone, whose axle shafts are next up in quality? - JeepForum.com
post #1 of 30 Old 08-26-2013, 09:49 AM Thread Starter
weerwolv
Hi all,
Going to go to alloy shafts on my D30 for extra strength up front and get the bigger U-joint. Staying with 27 spline. Have a leaking D30 passenger side shaft after TJ shaft conversion so I might as well do it all at once.
Who do you recommend for shaft quality and a fair price now that Superior is gone?
weerwolv is offline
post #2 of 30 Old 08-26-2013, 09:52 AM
sjones26573
TenFactory
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 30 Old 08-26-2013, 09:57 AM
zte87
GIVE IT THE ONION
zte87's Avatar
I have been happy with my Yukon shafts!
zte87 is offline
post #4 of 30 Old 08-26-2013, 10:04 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Ten factory or alloy USA.
Luck Favours The Prepared
Anticanman is offline
post #5 of 30 Old 08-26-2013, 10:36 AM
jbolty
jbolty's Avatar
My one experience with Alloy USA was not great. Have yukon now and have beat on them pretty good, so far.
jbolty is offline
post #6 of 30 Old 08-26-2013, 10:51 AM
jeepster93
jeepster93's Avatar
When it was my money:
Had them for about 35,000 miles and am pleased. (they are 30 spline though=stronger)
jeepster93 is offline
post #7 of 30 Old 08-26-2013, 11:44 AM Thread Starter
weerwolv
Thanks folks. Really appreciate the info on this. I was leaning toward 10 Factory but they don't advertise as hard as Yukon does so I wanted to make sure and I hadn't heard as much about them.
Seems like Yukon has BIG ad dollars for suppliers
weerwolv is offline
post #8 of 30 Old 08-26-2013, 11:48 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Alloyusa has a new type that's all pretty and gold. They're supposed to be improved. Either way, I went ten factory.
post #9 of 30 Old 08-26-2013, 11:52 AM
fratis
fratis's Avatar
Dutchman.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #10 of 30 Old 08-26-2013, 11:55 AM Thread Starter
weerwolv
Thanks for the quick update. Do the full shaft kits usually include the inner differential seal? Not sure about that. This would be when you eliminate the CAD system.
weerwolv is offline
post #11 of 30 Old 08-26-2013, 12:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My ten factory did. Otherwise if you want TJ shafts I will send you an extra seal I have.
post #12 of 30 Old 08-26-2013, 12:07 PM Thread Starter
weerwolv
HooRah and thanks for quick update. Nope I'm good on the seal. Placing order now for 10 factory kit.
Now to focus on rear axle choice...
Like the value of 8.8 but the low sitting diff and pinion offset (left to right) has me worried.
Any vibration with your setup?
weerwolv is offline
post #13 of 30 Old 08-26-2013, 12:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
With a SYE and DC driveshaft, there is zero vibration. If you were closer I would invite you for a test drive.
post #14 of 30 Old 08-26-2013, 12:34 PM
zte87
GIVE IT THE ONION
zte87's Avatar
The 8.8 is the way to go man I love mine, like anticanman I am also running c-clip eliminators kit with chromoly shafts. I am again running the ultimate 8.8 kit from Yukon back there!
zte87 is offline
post #15 of 30 Old 08-26-2013, 12:41 PM
jsawduste
2006 YJ Wrangler
Originally Posted by fratis View Post
Dutchman.
Best stuff out there.
I wouldn't touch Alloy or Yukon and 10 factory is only a minor step up.
jsawduste is offline
