Now mine won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Now mine won't start
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-06-2009, 05:42 PM   #1
BtownFord
Ok i have a 1990 wrangler with the 4.2 carb. stock carb and everything else as far as i know. It had a hesitation so i have replaced the following. Plugs, coil, and pcv. It still ran rough so i put new wires in it. I go to start it up and it just cranks and cranks and cranks. I smell fuel so its getting fuel. Everything spark related is in good condition and/or new. I don't know guys. The more i mess with it the more i get frustrated.
What gives guys? What else do i need to check
BtownFord is offline   Reply With Quote Quick reply to this message
Unread 02-06-2009, 05:44 PM   #2
Brandon_YJ
1987 YJ Wrangler
Have you "verified" spark?
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote Quick reply to this message
Unread 02-06-2009, 05:51 PM   #3
BtownFord
yes it is getting spark from the coil
Unread 02-06-2009, 06:03 PM   #4
bringbackphish
ive had wires that were new that were a POS and wouldnt carry the spark. Also are ur plugs gapped, i think its supposed to be .035
bringbackphish is offline   Reply With Quote Quick reply to this message
Unread 02-06-2009, 06:06 PM   #5
BtownFord
My plugs are gapped correctly. The same plug wires are used from the coil to distributer as the distributer to plugs. I will swap the plug wires back to the old ones tomorrow morning.
Thanks for the ideas guys, keep them coming though
Unread 02-06-2009, 06:13 PM   #6
Brandon_YJ
1987 YJ Wrangler
I meant did you verify spark at the plugs.
But from the way you are talking, it sounds like you know what you're doing and likely have.
FI engines have so much extra stuff on them that I have no idea how to diagnose their problems. With my carb, it's easy.
Sorry man, no help here
Unread 02-06-2009, 06:53 PM   #7
BtownFord
I haven't verified spark on the actual plug. Just to the distributor. Its dark here so no go tonight. One thing i did notice is that the new wires are 7mm and the old wires were 8mm. Will that make a difference?
Unread 02-06-2009, 07:05 PM   #8
Brandon_YJ
1987 YJ Wrangler
The difference in wire size will not be the cause of this issue.
Unread 02-06-2009, 07:47 PM   #9
bigsquat
if your getting spark at the plugs and at the right time and its getting fuel, then that only leaves compression, and or valve timming. but i dought thats it. dids you try spraying starter fluid in the carb?
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote Quick reply to this message
Unread 02-06-2009, 07:58 PM   #10
giixxer21
i have a 90 with a 4.2 stock engine...my choke gets stuck closed sometimes..like yesterday morning when it was 5 degrees. started up....warmed up drove off...and it closed. leaving me cranking and no start...just hesitation. i doubt you blew anything if it was running fine right before. nothing like a "carter" crappy carb. take the air cleaner off,and make sure its open. also a rebuild never hurts. or a damn good clean.
90' YJ 4.2L ,SOA 36' iroks, W/full cage
93' XJ stock
giixxer21 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2009, 08:02 PM   #11
johnnyfitz14
its your ecm going bad i had the same problem i just took the pos carter out and now im running a 2barrel weber and im so much happier
johnnyfitz14 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2009, 07:05 AM   #12
kmj153
Dumb question but you do have fuel in your gas tank? My fuel guage does not work the way it use to. Also my Ignition control mudule under the washer fluid resivior went up one time on the trail. No warning signs but it prevented the jeep from starting and I think I was getting some spark, just not continuous.
1990 YJ, Waggy 44's, 4.56, ARB's, 35's, 4.2 w/ Howell FI, Stak Dana 300 RAC, w/ JB 4:1 and 32 spline output, undercoverfab belly up
2005 F-150, DD/Tow rig
kmj153 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2009, 07:17 AM   #13
BtownFord
I filled the jeep up whhen i got it and only have 35 miles on tripometer. If swapping the plug wires back does not work, i guess i will just have to start throwing stuff at it.
Unread 02-07-2009, 07:26 AM   #14
pman
pman's Avatar
Did you ever verify spark at the plug? Also, aside from the smell, actually look to see that you're delivering fuel into the intake. (Also, I'd agree with BigSquat about hitting the carb with starting fluid..at least it's a cheap way to ensure fuel's not the issue). At least try to rule out these basics before you throw the spark box at it. That's a "non-returnable" item at most parts stores. However, from my 20+ years experience with my own YJ, the ignition module does tend to die "suddenly" and can create a host of symptoms, including flakey spark conditions.
I never knew the Ignition Modules could be checked for proper operation, but apparently from what I've read on the board here, Advance Auto/Autozone can do it.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
http://www.jeepforum.com/forum/f8/cj...-lulu-1350563/
pman is offline   Reply With Quote Quick reply to this message
Unread 02-07-2009, 12:16 PM   #15
BtownFord
ok so i've messed with it all morning and still can not get it to start. Where is the ignition control module and how to i get to it?
