Now I've done it.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Now I've done it....
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 12-26-2005, 05:20 PM   #1
skeletor
Went to remove "suspect" TPS and f'd up one of the torx head bolts !!!!.
The first one came out hard but is ok .
Should I take the TBI off,grind/dremel the head off the bolt then remove sensor and try with a pair of vise grips???
Any other ideas???TY...skeletor
skeletor is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 07:12 PM   #2
red92YJ
I messed up three removing my windshield brackets to mount lights. I just drilled them out and retapped the holes. If you use a bit a little smaller than the bolt the tend to go pretty easy and not damage the old threads too much. I used regular bolts to go back in, I wasn't going through that again! Good luck.
1992 red YJ soft top 4.0 w/5 speed BF Goodrich 31x10.50 M/T tires, 1.25" shackle lift, Rancho RSX shocks, Outland Neoprene seat covers, Outland Acoustic brief bikini top, KC lights (windshield and bumper)
Sound bar and JVC HD radio.
[URL="http://img.photobucket.com/albums/v369/timc/Non%20Gun%20pics/Jeepapril20071.jpg?t=1176762892"]http://img.photobucket.com/albums/v369/timc/Non%20Gun%20pics/Jeepapril20071.jpg?t=1176762892[/URL]
red92YJ is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 07:28 PM   #3
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Is the stripped torx head raised or sunk into whatever it bolts into? If it is raised and if you can get a grinder to it you can use the grinder to flatten out two opposite sides of the bolt, thereby allowing a regular wrench to go over it and then remove it.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 07:39 PM   #4
Mr. Notorious
If you do alot of wrenching on your jeep go out to Sears and get the Craftsman "Bolt outs". They are amazing! If you're looking for a quick fix you can try some vise grips or something but in the time it'll take you you could just drive to sears and buy this kit.
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 08:38 PM   #5
skeletor
Thank you Mr. N,Saw those on an info-mercial!!!!,I'll give it a shot!!!!...skeletor
Unread 12-26-2005, 08:43 PM   #6
YJBlues
X2 on the craftsman bolt outs, one of the most valuable tools in my toolbox. One thing I use on small torx bolts is my impact screwdriver, put the proper torx bit in the end, insert, give it a good whack with a hefty hammer, nine times out of ten it breaks loose on the first try.
YJBlues is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 08:51 PM   #7
CalicoYJ
You will definately use those bolt outs more than once they are a good investment. They are good for helping people out too everyone snaps bolts.
CalicoYJ is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 08:53 PM   #8
93Renny
Happened to me before, stipped out torx head. So I upped to the next size torx socket and pounded it into the stripped out hole. I then used an impact wrench and it poped it out enough that I could spray PB Blaster in the threads and used a pair or vice grips to work it loose (wrenching it left and right). The impact wrench finnished stripping the torx head out, but got it loose it for me.
I'm pretty sure it's ok to put anti-seize on the threads before putting the new bolts back in. It would assure you that you'd be able to remove them again if need be.
Anyone know about that?
1993 Jeep Renegade, 4.0 I6, 2.5 Rubicon Express Lift kit, 1 inch Shackles, BFG 32x11.50x15
Other add ons, TJ style Stainless hood catches, custom tow hitch......
93Renny is offline   Reply With Quote Quick reply to this message
Unread 12-26-2005, 09:01 PM   #9
CalicoYJ
Anti-sieze is fantastic except sometimes fibrations can work things loose. It never hurts to try it though as long as you check back once in a while to make sure its not ready to fall out.
Unread 12-26-2005, 10:06 PM   #10
skeletor
The one that came out had abt the last quarter of an inch of some type of coating on it(lock-tite?),fought me all the way!....skeletor
Unread 12-27-2005, 01:34 AM   #11
toplessjeep
Yeah anit sieze is great. Yeah you gotta make sure you tighten it properly. I was tought in school to use it on lugnuts when ever you remove the wheels. You only gotta do it once in a while not evey time. Never ever had any lug nuts come loose. Stil I always worry so I double check everything again the next day after driving for a while.
toplessjeep is offline   Reply With Quote Quick reply to this message
