Novak 231 Shifter Kit issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Novak 231 Shifter Kit issues
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-03-2014, 12:16 AM   #1
zippoguy
Hi all, I had my Novak shifter kit along with SYE, rebuilt the 231 TC, new driveshaft installed today by a Jeep specialist.
Having some issues with the TC shifting:
If Jeep is on Drive, the transfer case will shift from 2h straight to neutral, skipping 4h.
If the Jeep in on Neutral, transfer case would shift normally - 2h-4h-n-4l
The Novak shifter knob wobbles, not firm.
Everything was installed per their instructions and double checked, any suggestions would be appreciated.
Few other things that started happening after the installs (just in case it would help to figure out the problem(s): Speedo stopped working completely (used to work, just not correct speed), transmission shifter too sensitive, you have to shift extra carefully from P to N, etc, otherwise it skips easily and the arrow on the column indicator is a bit off, no matter what it's on. Check engine light came on (code 36, I read the code definitions, can't really be 36, but double checked 20 times, and it does give a 3-6; 5-5).
The RPMs are higher than usual (it was always high as I am on 4.56), but it seems very high, around 3KRPM at 25mph. That I have to double check when I go at over 55mph though, I might be wrong.
It is a 1993 YJ, 3 spd Auto, 4.56 gears, approx 4.5" lift.
Thanks much in advance.
zippoguy is offline   Reply With Quote Quick reply to this message
Unread 10-03-2014, 09:56 AM   #2
Randonexplosion
Randonexplosion's Avatar
Is it the cable shifter or the "builder kit"?
5.3/4 link build
Looking for 92+ front female seatbelts
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 10-05-2014, 12:06 AM   #3
zippoguy
Builder kit, it's on a yj.
Unread 10-06-2014, 09:22 AM   #4
Randonexplosion
Have you talked to the shop to see what they say about your issues? On the Novak shifter they use 2 shouldered washers where the 2 plates meet so it swings freely. I found that it wobbled too much as well, and after a phone call to Novak they suggested grinding down the shoulder a little at a time to tighten it up. Mine would lean over and vibrate on the tunnel cover.
5.3/4 link build
