Nothing When Trying to Start - Page 3 - JeepForum.com
post #31 of 37 Old 10-24-2013, 06:30 PM
pete1991YJ
X2 on smacking it with a hammer. I found that the Bosch solenoids are a bit "tight" the way they fir the plunger, sometimes they stick. Also like Que said on the brushes. Usually having to smack it every time means the starter is going and needs a rebuild or replace. You might be able to fix it with a real good cleaning tho, I just took mine all apart and used solvent with rags.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #32 of 37 Old 10-24-2013, 06:38 PM Thread Starter
huntdogg
I can try, but I would have figured it loosened up when I had it working on the floor. I can take a hammer to it and make SURE I'm going to need a new one though! Lol
huntdogg is offline
post #33 of 37 Old 10-24-2013, 06:58 PM
Que89YJ
That is just it. It doesn't fix it. The brushes will still end up getting hung up again. You might have jarred them taking it off. You just need to tap it. You have my number. Call when you get back. You need ri be there for the family right now. We will get you going.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #34 of 37 Old 10-24-2013, 07:37 PM Thread Starter
huntdogg
Thanks, bud. We are about to head out, so I will pick it back up with you guys after the weekend.
huntdogg is offline
post #35 of 37 Old 07-07-2014, 07:36 PM Thread Starter
huntdogg
So, I'm checking back in to update you guys on what ended up happening. After several times of pulling the starter and successfully bench testing it, only to have it not start when I put it back on...as well as many other tests that involved re-routing wires and jumping terminals and cleaning grounds and replacing the ignition switch...and blah blah blah...
My dad (who is usually never stumped) said "have someone turn the key and reach under there and tap it with a screwdriver," which sounded awful familiar to some advice I'd received on here ...and I'll be damned if it didn't fire right up. Pulled it off and bought a new one that night and she's been starting strong ever since.
If someone...ANYONE...can learn anything from this, I pray it saves you the frustration!
huntdogg is offline
post #36 of 37 Old 07-08-2014, 06:31 AM
Que89YJ
The testing for alternators and starters doesn't always tell you the entire story. Glad to hear you got it running.
post #37 of 37 Old 07-08-2014, 07:13 AM
TSEJEEPERS
Thanks for getting back to us on your solution.
So many of these posts just die. People get their Jeeps fixed and never post back the results.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
