Nothing turns on - ignition switch? - JeepForum.com
post #1 of 13 Old 11-22-2013, 01:35 PM Thread Starter
Plyj
I've been having issues with my '90 YJ. It had intermittent starting problems after I replaced the intermediate steering column.
Sometimes it would start just fine and sometimes no starter but the dash lights & heater worked (I could jump across the starter with ignition key on and it started fine).
Now, no dash lights, no heater, no ignition... no nothing (starter turns over when jumped but won't start). I'm thinking ignition switch. Does that make sense? I've read a few write ups on replacing the switch so I'll probably do that as a first step.
Plyj is offline
post #2 of 13 Old 11-22-2013, 03:57 PM
jbolty
jbolty's Avatar
Good guess.
First, get a helper and a volt meter. Check the fusible links to make sure you're getting power to the fuse block; sometimes those burn partially. Also see if the power from the switch to the starter relay is working. Green wire, as I recall.
jbolty is offline
post #3 of 13 Old 11-22-2013, 06:13 PM
Old4X
1990 CJ7
As you just worked on the steering column, that is a good place to start.
hint: the electrical part of the ignition switch is on it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 13 Old 11-23-2013, 01:56 PM
rubisean
take the ignition switch off the column, manually work the switch with a small screwdriver. the spring loaded position is the start position. if that works then it is a simple matter of adjusting the switch
rubisean is offline
post #5 of 13 Old 11-25-2013, 12:07 AM
Opihi59
from here it gets rough
Opihi59's Avatar
http://www.jeepforum.com/forum/f12/b...witch-1226376/
Just in case it helps.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #6 of 13 Old 11-28-2013, 05:08 AM Thread Starter
Plyj
Well... it wasn't the ignition switch.
Swapped in a new one (nice write up Opihi) and still nothing.
Guess I'll have to trace it now.
Plyj is offline
post #7 of 13 Old 12-02-2013, 07:26 AM
Que89YJ
Get a meter and check the output of the ignition switch and the input at the starter relay.
Here are the links to download the FSM to trace the wires back:
http://dl.dropbox.com/u/40590346/87-88%20YJ%20Jeep%20Wrangler%20FSM%20manual.pdf
http://dl.dropbox.com/u/40590346/1990%20Jeep%20Factory%20Service%20Manual.pdf
Que89YJ is offline
post #8 of 13 Old 12-02-2013, 08:24 AM
jaycal3
May be a long shot but easy to check... I would look at the ground wire off the battery to the block. I had the same symptoms a while back and found that it was exactly that. Got new battery wires and terminals and installed and cleaned the area it attaches to the block for clean solid contact and voila.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #9 of 13 Old 12-02-2013, 08:34 AM
jbolty
jbolty's Avatar
No matter how long I live I'll never understand tossing parts at a problem with diagnosing it first.
jbolty is offline
post #10 of 13 Old 12-02-2013, 09:16 AM
Old4X
1990 CJ7
But... a meter costs 10 bucks! The part was only $155.00 ...........
Old4X is offline
post #11 of 13 Old 12-02-2013, 06:57 PM Thread Starter
Plyj
Put the column (w/ new switch) back together and looked at the starter relay (bolted to fire wall).
One wire (off the main pwr post) was smoked... looked like an old problem but jumpered across it anyway and got dash lights (also got pwr to starter relay).
That seemed encouraging so I shorted across starter... she started and ran perfectly.
Ordered a new starter relay (everything up to it else seemed fine) since that is the likely suspect.
No disrespect but it's often less time consuming (and cheaper) to toss parts at a problem than spend days tracing/diagnosing an issue... especially if the parts are cheap and time is limited (or you're working in the driveway and it's below freezing).
Plyj is offline
post #12 of 13 Old 12-03-2013, 08:58 AM
Que89YJ
I will give you the cold thing....but not cheaper!
Glad to hear you got it runnin'.
Que89YJ is offline
post #13 of 13 Old 12-04-2013, 08:06 AM Thread Starter
Plyj
I believe I've found the problem...
After I repaired the smoked wire (fused it w/ small fuse - 10A), I had instrument lights and, therefore, pwr to ignition coil.
It started fine and ran great (as always) but when I put the heater on full, the fuse pops (much better than burning more wire) leading me to suspect that everything (dash-wise) is on the same circuit.
Well, last summer I did the blower motor upgrade (older blazer motor fits great and delivers a hurricane of wind). I'm guessing the new motor pulls lots more current than the OEM and overloaded the circuit (don't know why junction box fuse didn't blow - maybe too big a fuse), smoking the wire. So, I ran a separate circuit (with relay & fuse) for the blower motor and haven't had any problems since.
Thanks everyone for the help... I'm happy !
Plyj is offline
ignition switch , YJ
