Not your normal SYE question. - JeepForum.com
post #1 of 6 Old 12-02-2012, 05:50 PM Thread Starter
scastleton
My friend has a 1989 YJ with a 4 Inch lift on it. He wants to know if you need to do a SYE conversion when you get a new driveshaft.
I've never seen this question on the forum so I assumed it wasn't normal.
scastleton is offline
post #2 of 6 Old 12-02-2012, 06:03 PM
Bong_Holyeo
Yes a SYE is some of the best money your "friend" will spend on his jeep..
Bong_Holyeo is offline
post #3 of 6 Old 12-02-2012, 06:15 PM
Michaelgoesrawr
I thought this wasn't a normal question?
You should have an SYE with that much lift and a new driveshaft is needed. It is a shaft that has a Double Cardan that bolts to the SYE. Check here for the shafts http://www.4xshaft.com/
Michaelgoesrawr is offline
post #4 of 6 Old 12-02-2012, 06:26 PM Thread Starter
scastleton
It is my friend. I have a bone stock TJ
post #5 of 6 Old 12-02-2012, 07:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You need a new driveshaft when you get a SYE. Start with SYE then choose the driveshaft to match. Not the other way around.
Luck Favours The Prepared
Anticanman is offline
post #6 of 6 Old 12-02-2012, 07:41 PM Thread Starter
scastleton
Ok. Thanks. That was very helpful
