Not a Wrangler Guy, Forgive my Ignorance - Backspacing - JeepForum.com
post #1 of 8 Old 04-28-2015, 10:35 AM Thread Starter
pat85
As title states, I'm not a Wrangler guy, I'm posting for a friend. He just picked up an '89 and is in parts ordering mode. He's enlisted my help because I'm the mechanical one between the two of us. I've been reading through some older threads and I've found unclear answers. I'm looking to see what backspacing will be appropriate for his soon-to-be setup. I want to avoid rubbing at full locks and also at available flex. But that the same, I don't want his tires sticking out to next week.
89 YJ
2in lift springs
.5in lift shackles
31x10.5/15 Duratracs
Thank you in advance.
If it works, it works...do it for you.
His: 01 WJ Storm Trooper
Hers: 14 FDII Patriot
Sold: 98 ZJ
pat85 is offline
post #2 of 8 Old 04-28-2015, 10:39 AM
glenn-91YJ
glenn-91YJ's Avatar
8" wide rims with 3.5" backspacing for those tires will be fine.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #3 of 8 Old 04-28-2015, 10:41 AM Thread Starter
pat85
I figured as much on the 8" wide. 3.5" is more than I was anticipating. But that's why I asked!
Thank You!
Sold: 98 ZJ
pat85 is offline
post #4 of 8 Old 04-28-2015, 10:53 AM
Crunko
3.75 is fine
Crunko is offline
post #5 of 8 Old 04-28-2015, 10:57 AM Thread Starter
pat85
Originally Posted by Crunko View Post
3.75 is fine
I was about to ask the consensus on those. I found a set up Pro Comps that right up my friend's ally that are 3.75. I figured it would be a negligible difference but, again, not familiar with Wranglers.
Sold: 98 ZJ
pat85 is offline
post #6 of 8 Old 04-28-2015, 11:00 AM
Crunko
Yeah 3.75 is more common on wranglers and with your 10.5 wide 31s it will be just fine.
Crunko is offline
post #7 of 8 Old 04-28-2015, 11:10 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Even less backspacing would work. When I first got my Jeep it had 30/9.50s on it with stock wheels (5.5" backspacing) and it barely rubbed at full lock. I'd say around 4-4.5" would work. For reference I am running 35/12.50s on 3.75" backspaced wheels with a skinnier-than-stock 8.8
Randonexplosion is offline
post #8 of 8 Old 04-28-2015, 11:31 AM Thread Starter
pat85
Awesome. Thanks guys.
Sold: 98 ZJ
pat85 is offline
