Not getting spark - loose wire - JeepForum.com
post #1 of 6 Old 09-24-2010, 03:02 PM Thread Starter
kadgarth
1987 YJ Wrangler
So I'm not getting a spark right now. I think I've traced the problem to a stray wire but I don't know where this wire goes exactly. I have an idea but before I break something I figured I'd post a picture and take it from there.
I think it goes to the place I have the arrow pointing, but I havn't the slightest clue as to what that object is, or how I'd reattached the wire internally.
*Note* Go to the following link for a larger size picture: http://farm5.static.flickr.com/4132/...fac040e0_o.jpg
Thank you!!
kadgarth is offline
post #2 of 6 Old 09-24-2010, 05:20 PM Thread Starter
kadgarth
1987 YJ Wrangler
No thoughts?
kadgarth is offline
post #3 of 6 Old 09-24-2010, 08:48 PM
jsawduste
2006 YJ Wrangler
To the coil where you have it circled.
jsawduste is offline
post #4 of 6 Old 09-24-2010, 09:01 PM Thread Starter
kadgarth
1987 YJ Wrangler
Is there some way to take the top off the coil so I can reattached the wire?
kadgarth is offline
post #5 of 6 Old 09-24-2010, 09:40 PM
jsawduste
2006 YJ Wrangler
Nope, replace it.
post #6 of 6 Old 09-25-2010, 12:55 AM
greyarea
This would be a great time to do the team rush upgrade. You can also get that connector at the parts store.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
Alternator plug wire comes loose. jamie2727 TJ Wrangler Technical Forum 2 01-26-2010 06:00 PM
Loose Ground Wire, from where?! Voyame JK Wrangler Technical Forum 4 01-13-2010 03:09 PM
NEED HELP-Wire came loose under dash mudmachine25 TJ Wrangler Technical Forum 2 11-25-2009 07:10 PM
Loose wire in engine compartment... what is it? mahgnillig TJ Wrangler Technical Forum 9 08-29-2008 10:45 AM
what the heck, fuse or loose wire? Guitarhead09 TJ Wrangler Technical Forum 6 12-23-2007 02:11 PM
