Not charging/ Check engine light - JeepForum.com
post #1 of 8 Old 05-21-2010, 07:51 PM Thread Starter
superman_jjs
the CEL came on and I noticed that my voltage was low.
I broke out my charger that has a charging system tester and it showed a big fat goose egg (0). I had the altenator tested and it was good.
I was unable to find a voltage regulator and was told, by the parts store and the dealership, that the voltage regulator is in the ECU.
my question is could it be something else?
how often have you seen the ECU going out for the voltage regulator?
Thanks,
superman_jjs is offline
post #2 of 8 Old 05-21-2010, 08:00 PM
Mark05059
its more common to find the 2 fuses blown for the alternator then the ECU bad.
Check those first.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 8 Old 05-22-2010, 11:04 AM Thread Starter
superman_jjs
Thanks, i will have to take a look at the fuses.
post #4 of 8 Old 05-22-2010, 11:07 AM Thread Starter
superman_jjs
I dont have the orginal engine compartment fuse box cover.
Can someone provide a listing of the layout for the fuse box?
Thanks
post #5 of 8 Old 05-22-2010, 11:33 AM
Roadyy
Did you only have one parts house test it?
We have seen several times where 1 said it was good and the next one said it was shot.
Some of those testers aren't very accurate.
We just went thru this on another thread in here.
Look thru the search feature and you will see what I mean.
I'm at work at the moment and don't have my book with me. I'm sure you can find it if you use the search tool at the top center of the thread list.
Happy hunting and sorry I couldn't help anymore than this for now.
Another tip for finding out if it is indeed the alt. Check your cel codes and see if you are getting an alt. field code, if so then I would go buy a new alt.
Roadyy is offline
post #6 of 8 Old 05-22-2010, 01:15 PM Thread Starter
superman_jjs
Thanks for the info.
i am getting the 41 alt field code
is there a difference between the 75 and 90 amp alt other than the amp difference?
I pulled out he fuses yesterday and none seemed to be bad.
post #7 of 8 Old 05-22-2010, 05:57 PM Thread Starter
superman_jjs
Thanks for the help.
I took out the alt again and just replaced it.
like magic it worked.
post #8 of 8 Old 05-22-2010, 09:24 PM
Roadyy
You are very welcome,Glad you are back on the road again.
Roadyy is offline
cel , check engine light , computer , ecu , voltage
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 02:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 09:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 09:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 05:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
