Normal for Rugged Ridge SYE? - JeepForum.com
post #1 of 6 Old 06-30-2013, 06:46 AM Thread Starter
jason280
I installed a Rugged Ridge SYE about 2-3 weeks ago, and all went well for the most part. I had to go back under the Jeep to rotate my speedometer gear last week, and noticed that I had a large amount of surface rust on the driveshaft yoke. Anyone else had this issue? I know its superficial, but I am a little surprised it happened this quickly considering the Jeep stays in a garage and has not seen any rain or water.
As a comparison, here is a pic of an unpainted boom shackle that was mounted a couple of weeks before the SYE, and it has very little (if any) surface rust.
In fact, the boom shackles have virtually no rust on them at all, whereas the RR yoke is covered. Is this normal?
jason280 is offline
post #2 of 6 Old 06-30-2013, 07:17 AM
crackedcornish
normal...if rust worries you, paint it with some Rustoleum Hammered
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 6 Old 06-30-2013, 07:41 AM
superj
Maybe there is more heat cycles on the sye then the shackle? That will make surface rust appear faster
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 6 Old 06-30-2013, 07:43 AM
SeanB95YJ
it's the humidity (late June in GA)... and those booms to me DO look like they have paint on them - they're black same as your springs... you can see the bolt head has a little surface rust around the edge where your wrench shipped through some of the paint.
you can either paint the yoke, or do what I do... put a dab of grease on your finger and put a super-thin coating all over the yoke and CV housing
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 6 Old 06-30-2013, 08:34 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Rattlecan.
Luck Favours The Prepared
Anticanman is offline
post #6 of 6 Old 06-30-2013, 03:41 PM Thread Starter
jason280
No, the shackles have not been painted, i believe its just the lighting in the pic that makes them look black.
I probably clean it up a bit and hit it with a few coats when I paint the 8.8 in the rear.
jason280 is offline
