-   -   Normal for Rugged Ridge SYE? (http://www.jeepforum.com/forum/f12/normal-rugged-ridge-sye-1543043/)
jason280 06-30-2013 06:46 AM
I installed a Rugged Ridge SYE about 2-3 weeks ago, and all went well for the most part. I had to go back under the Jeep to rotate my speedometer gear last week, and noticed that I had a large amount of surface rust on the driveshaft yoke. Anyone else had this issue? I know its superficial, but I am a little surprised it happened this quickly considering the Jeep stays in a garage and has not seen any rain or water.
http://i15.photobucket.com/albums/a3...psc36c9662.jpg
http://i15.photobucket.com/albums/a3...ps06befe23.jpg
As a comparison, here is a pic of an unpainted boom shackle that was mounted a couple of weeks before the SYE, and it has very little (if any) surface rust.
http://i15.photobucket.com/albums/a3...psb1a2c2f9.jpg
In fact, the boom shackles have virtually no rust on them at all, whereas the RR yoke is covered. Is this normal?
crackedcornish 06-30-2013 07:17 AM
normal...if rust worries you, paint it with some Rustoleum Hammered
superj 06-30-2013 07:41 AM
Maybe there is more heat cycles on the sye then the shackle? That will make surface rust appear faster
SeanB95YJ 06-30-2013 07:43 AM
it's the humidity (late June in GA)... and those booms to me DO look like they have paint on them - they're black same as your springs... you can see the bolt head has a little surface rust around the edge where your wrench shipped through some of the paint.
you can either paint the yoke, or do what I do... put a dab of grease on your finger and put a super-thin coating all over the yoke and CV housing
Anticanman 06-30-2013 08:34 AM
Rattlecan.
jason280 06-30-2013 03:41 PM
No, the shackles have not been painted, i believe its just the lighting in the pic that makes them look black.
I probably clean it up a bit and hit it with a few coats when I paint the 8.8 in the rear.
The time now is 01:38 PM.
